help! el gauges won't turn on!
Old Jul 14, 2002
mastercave's Avatar
mastercave is an unknown quantity at this point
I need help with my el gauges from autodynamic. I connected the red wire to the red/black wire on the blue gauge thing and I grounded the black wire, but when I try turning them on, nothing turns on. The needles glow so I know the stock gauges are working, just something wrong with the new gauges. Anyone know what to do?
Old Jul 14, 2002
Hedonism's Avatar
Hedonism is an unknown quantity at this point
maybe its the inverter
Old Jul 14, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
Check all the wires make sure its grounded correctly. Make sure you connected it to the red/black wire coming from the blue connector
Old Jul 14, 2002
mastercave's Avatar
I think it may be the brain. I used a volt-meter and the red wire going to the brain has a constant 12v. I then tried the wires coming out of the brain to the dimmer switch, which had to power. Anyone know if it's possible to buy just the brain?
Old Jul 14, 2002
thx1138's Avatar
thx1138 is an unknown quantity at this point
Just something out of the blue, don't know if it'll work. The gauges come with that 2 button switch for changing color and intensity. The switch has it's own connector. You can fit that on 2 ways, so 50% chance. Unless it doesn't matter which way you put it on. I haven't tried that on mine. But you could try to put it on the other way. And you might wanna check the other connectors from the brain to the gauges.
Old Jul 14, 2002
atomicblue's Avatar
atomicblue is an unknown quantity at this point
their probably broken
Old Jul 15, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Universal Inverter at AutoDynamic.com but try checking the DIY made for it incase you missed something.
HTH
-Kre
Old Jul 16, 2002
notorrious's Avatar
notorrious is an unknown quantity at this point
i had the same problem with mine the other day and i went to buy a test light to test the red/black wire and it was the right wire. for some reason my guages worked last night when i installed them again. just one thing though when i hooked up the color control and dimmer,(that wire coming out of the brainbox that controls the color of your lights, with the big red circle at the end of it) my lights went off. then i unhooked that controler tab and they came back on. so my indiglos are stuck at a light green with blue numbering, which is cool anyways.
Old Jul 16, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Mine used to work all the time, now they hardly ever work... sometimes they are on, then they just go off, and then back on at random... It really pissed me off how cheap these things are made. I have th AC autotechnic ones, I have checked my wires several times, right now I hard wired them directly to positive/negative and I still have probelms, I think I might have to get some new ones...
usajags84
May 10, 2015 08:11 AM
tylerginevan
Apr 27, 2015 12:29 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
