need help cleared headlights fogged?
Old Jul 12, 2002
Hawk's Avatar
You boost, I-VTEC
need held cleared headlights fogged?
ok i just cleared my headlights, i went for a drive and when i returned i noticed that they looked fogged up. the weird thing is that its not raining out, nor is it very humid. my question would be is there a way i can defog them without taking them apart again? or is there some underlineing reason why they fogged? help is appreciated.
Old Jul 12, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you probably need to reseal them. a double-seal would be your best bet
Old Jul 12, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
yes they most likely just need some more kitchen/bath silicone
Old Jul 12, 2002
Hawk's Avatar
You boost, I-VTEC
i put a crap load of silicone in there, is there away to defog them without reseperating them?
Old Jul 13, 2002
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
reseal with window clear silicone.... use a shizt load everywhere.... and just peel the remmaining stuff
after you've dried..... but only if you want too or feel there is too much clear silicone on it
Old Jul 13, 2002
marker126's Avatar
marker126 is an unknown quantity at this point
There's a little vent on the back of the lights...it has a small piece of foam in a clear plastic tube like thing. See if that's clogged up....I had a car and the lights would always fog up when i went through the carwash...it turns out this little vent was clogged...
hope this helps..
Old Jul 13, 2002
HarryDong's Avatar
HarryDong is an unknown quantity at this point
I just wanted to let you guys know that instead of gobbing my headlights with silicone after
I cleared them, at the recommendation of a friend I put them in the oven for about 3 min at
170 degrees and they resealed PERFECTLY! I didn't have to use any silicone, it just resealed
with the factory goop and I've already driven through a torrential rain and I live in a very
humid area and have had no problems... I think they should add this method to the DIY section,
since I found a couple of things superfluous in there. Just heat them up, take them out, and
MASH like hell! I know this is too late for you, but for future reference...
Old Jul 13, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
good idea harry
Old Jul 13, 2002
speedracersong's Avatar
u could also just use a hair dryer to get the water out.
Old Jul 13, 2002
Fructose's Avatar
Fructose is an unknown quantity at this point
Harry, I think I will have to try that now...thanks!
Old Jul 13, 2002
Hawk's Avatar
You boost, I-VTEC
on thing that i was confused about the diy instructions was there where hex bolts not philips head screws inside the headlights i thought that was odd. im gonna try that vent thing and or a hair dryer if that dosent work.
thanks for the help
Old Jul 13, 2002
Lrguy2's Avatar
Lrguy2 is an unknown quantity at this point
when you put the silcone on rub a inger across the seal to help push it down into cracks
Old Jul 13, 2002
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: speedracersong
u could also just use a hair dryer to get the water out.[hr]
the hairdryer worked like a charm, the seal seems to be fine becaue i hosed them down after fixing the fog in there. it seems when i put the headlight blubs back in the boot wasn't on all the way. so thanks for the help. Man i love this site!
Old Jul 16, 2002
Brett02eX's Avatar
Brett02eX is an unknown quantity at this point
i have a question, when i clear my headlights is the turn signal bulb flash orange ..if it does, why is there the orange piece of glass in there?
Old Jul 17, 2002
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
No, the bulb is just clear. You'll need to buy an amber or orange bulb to put in its place or you'll get pulled over like i did. The amber piece of glass is there cause its required by law. But just take the orange part out and leave the clear reflector and and an orange bulb and you'll be legal. You can take the clear reflector part out too(you'll know what I mean when you clear yours) but its illegal. I know here in NJ you can fail inspection for it.
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
