Engine vibration when idle
My car vibrates excessively when idle. Specially when the rpms drop like when I turn on the AC. I have a SRI, HP race headers, high flow cat & magna flow cat-back. Can any of these mods be creating the problem? Can it be a balance isssue since the header weighs more than the stock manifold?
I have the same mods as you do and i dont believe they would cause the problem unless they were installed wrong...take it to the dealership if all else fails...as for the balance issue...it shouldnt be an issue at all the header should be bolted down and wouldnt cause the vibs when idle...
your may have a broken motor mount. same things where happening to me on my last car. turned out rear right motor mount was broken
Proud Protaganistic Propagandist
It may be the air/fuel ratio not mixing correctly. A friend of mine had the same problem in his civic and the apexi air/fuel controller solved that problem.
Then again it may be other htings also. *shrug*
I have an AEM cai, pulleys, DC header, and cat back. I also had the same problem with a rough idle.
My car eventually stalled out every time I stopped at a light. I took my car to my mechanic and he raised the idle slightly and that solved the problem. I think it does have something to do with the air/fuel ratio. But after he raised the idle no more problems.
mine is stock except for irridium plugs and AEM cai and I have the same problem when the air is on just happend last night for the first time. then again it is also the first time I hav used the AC since I got my car [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
mikemc422
Aug 9, 2018 05:41 PM
mrohitredd
18
May 14, 2015 07:35 PM
jakeconnor
May 5, 2015 07:30 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
streetglower123
Apr 12, 2015 10:56 AM
