ATTN: BLUENVY01 and Others..... Question about puttin HP headers + Greddy Evo on the LX
Old Jun 21, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
I tried PMing BLUENVY01, but he don't have it configured to accept PM's. He has put HP headers w/ high flow cat and the EX greddy exhaust on his LX. I know there are problems with the HP headers, but I am wondering if there are any problems with the pipe connections from the HP headers to the end of the exhaust. Anyone else do this other than BLUENVY01? I was wondering if there were any type of modification needed to fit the piping and exhaust under the EX, like adjustment of the hangers or other things. Anyone know/done this?
Old Jun 22, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
the cat back should just bolt up. as for the header all i had to do was take out the front motor mount and shave the one part down a little. you'll see where to shave when you try to put the header in. and to make it easier and much faster i just took out the left motor mount and jacked the one side of the engine up a few inches. sounds like a lot of work but only takes about an hour
Old Jun 22, 2002
Quote
[hr]Originally posted by: 01civ01
the cat back should just bolt up. as for the header all i had to do was take out the front motor mount and shave the one part down a little. you'll see where to shave when you try to put the header in. and to make it easier and much faster i just took out the left motor mount and jacked the one side of the engine up a few inches. sounds like a lot of work but only takes about an hour[hr]
I'm not worried about the headers fitting the exhaust. I called HP and they said that the engine mount and fitment problems should be cleared up in 4 weeks and then shipped. I'm just worried about the greddy evo catback actually bolting upto the high flow cat and its hangers being able to hang were the factory pipes hang.
Old Jun 22, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Okay here's the deal if you have a LX or what not and you want to add a HEADER (not headers) to your car....
You gotta ditch the stock front sway bar, and get an EX exhuast system (obviously)....You can choose to leave it off I guess, but I would suggest getting a new sway bar since the car would be kinda "loose".....
It's just a bolt on, but yah you gotta shave one of the engine mounts.... :/
Old Jun 24, 2002
HondaCoupe's Avatar
HondaCoupe is an unknown quantity at this point
how can you just switch the header for the cat/exhaust manifold on the LX? what bout the o2 sensor?
Old Jun 24, 2002
Its just a simple bolt on.......remove the front sway bar, remove the whole exhaust system, and bolt on the new rig....you gotta shave part of the engine mount for the HP header tho....The O2 sensor...those wires are just extended and you're set!
martinsmartin
Aug 15, 2015 07:34 PM
Misfit2613
Jul 30, 2015 09:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
