Grinding Noise...when i accelerate..FIXED!!!!!!!
Old Jun 19, 2002
fourkilos's Avatar
fourkilos is an unknown quantity at this point
i had this problem yesterday... i was driving ..came to a full stop and then press on the gas to go.. and i hear this loud grinding, kinda rattling noise from my car, also when i turn and accelerate at the same time. i think its coming from the front right side of my car. so this morning i take it to my friend's shop ..and the damn thing doesn't make a sound. but as soon as i leave.. it starts again!! does anyone have this problem?? i searched the previous threads but no one seems to know what it is.
*****FIXED******
i took my car to my friends shop and it turns out that my DC strut bar was loose. he tighten all the bolts and now the sound has stopped. so all u guys with the same problem hope this helps!!!!!!!!!
Old Jun 19, 2002
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
http://www.2k1civic.com/forum/messageview.cfm?catid=7&threadid=40174&STARTPAGE=1
Check out that thread...sounds like that might be your problem...Does it only grind in second gear when you are turning? The wheel can be just slightly turned to the right in second gear and you'll hear a "grinding"
sov82
Old Jun 19, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
you killed your clutch IMO. its having problems engaging i think
Old Jun 19, 2002
fourkilos's Avatar
does it help if i say i drive an auto??
Old Jun 19, 2002
gurneelx's Avatar
gurneelx is an unknown quantity at this point
is your car dropped? do you have aftermarket rims on the car?
Old Jun 19, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
check your oil. it could be low. seriously
Old Jun 19, 2002
fourkilos's Avatar
no its not dropped.. and only MOD i did was intake and rims..and thats been there for like 3 months..and i only have 8000 miles on it . the sound is bugging me.. i'm more afraid of my car falling apart then anything rite now.
Old Jun 19, 2002
gurneelx's Avatar
if the intake is cold air, check out the filter. does it fot tight? make sure that thing is not hitting anything. the only other thing i can think of is taking out the right front rim and inspecting everything. check the panels that are right under the wheel well and see if anything is loose. it doesn't seem to me that the noise is coming directly from the engine. if it was, you would be able to tell right away.
Old Jun 19, 2002
symmetry's Avatar
symmetry is an unknown quantity at this point
haven't hit any cats have you? that would be good for the world, bad for the car.[IMG]i/expressions/laugh2.gif[/IMG]
Old Jun 21, 2002
cable's Avatar
cable is an unknown quantity at this point
fourkilos,
i began to get this problem. did you find a solution or the reason for the grinding noise??
Old Jul 10, 2002
fourkilos's Avatar
*****FIXED******
Old Jul 11, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
I had the problem u have but than....... it was my plastic underbody cover..... my rims were hitting and grinding onit
whenever i was turning a full rotation on my steering wheel...... also now my coils sweek a little..... so that sucks.... gotta
brake them suckers in.
Bonobo
Oct 2, 2015 06:58 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
siliconvalley
Sep 15, 2015 09:48 PM
duhwubwub
Sep 10, 2015 11:00 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
