Starter Motor and Clutch question
Hi everyone, would be grateful for some opinions.
I have just purchased a 2009 1.8 manual Civic with around 90,000 miles on it and a mostly full service history.
I have had similar aged mazda and fords in the past where I have had the starter motors fail at this age. I can not be left stranded out and about, so I have contacted Honda and asked them how long the starter motors were designed or expected to last. They were unable to answer (even their head office in Japan). Does anyone have any anecdotal experience? Obviously, there is a huge amount of variables and no guarantees. But how long do these tend to last? Do they start failing after i.e. 15 years 100,000 miles?
Then a question about the clutch. This is my first civic, but the clutch seems too snappy and sharp. Nothing happens until the clutch is let out a long way and then the car just snaps in to gear. Sometimes getting in to second can be almost grinding. I have heard some people say on forums this is normal, but is it?
Many thanks
Many thanks
Re: Starter Motor and Clutch question
I can count on one hand the number of starters I've replaced on the many Honda's I've worked on. It's two. Like an '06 Accord with maybe 185k miles had a failed starter. My dad's '07 Pilot with about the same mileage. I'm not a Honda mechanic working at a dealership so maybe someone else has better info. Even if the starter does fail, you have a manual transmission and could push start it.
I believe the clutch pedal has some adjustment to it you could try. Or maybe you just need to get used to it?
Kevinleyster
General 8th & 9th Gen
Dec 8, 2018 04:42 PM
Mckenneth
Dec 9, 2017 08:42 PM
pnamajck
Jan 8, 2011 07:07 PM
