Engine ticking or rattling noise at cold start in Reverse or Drive [solved]
Old Apr 24, 2023
Titi's Avatar
Titi is an unknown quantity at this point
Hi, I have a Honda Civic 2012, 105K. It started to do a rattling sound at cold start, when I move from Park to Drive or Reverse. If I move to Park again the sound dissapears. After the engine gets warm, the sound disappears.
Here is a recording on the sound: IMG_8658
You can hear the rattling noise appearing and disappearing, as the car is moved from park to reverse and back.
Do you have any ideas what it can be?
The engine works fine, all liquid levels are good.
Thanks
Old Apr 24, 2023
re: Engine ticking or rattling noise at cold start in Reverse or Drive [solved]
open hood, have someone look at it while you start.
screwdriver can be used as a stethoscope to pinpoint noises
if nothing found, lift car and do same under car.
or take somewhere to diagnose.
Old Apr 25, 2023
Colin42's Avatar
Could be a heat shield
Old Apr 29, 2023
Titi's Avatar
It was a heat shield. Thanks for the help.
Old Jan 21, 2024
civicsirules12's Avatar
civicsirules12 is an unknown quantity at this point
Re: Engine ticking or rattling noise at cold start in Reverse or Drive [solved]
Hi, my 2012 Civic is doing the exact same thing…. can you please tell me which heat shield it was and where?
Thanks!
Old Jan 21, 2024
lift car inspect, could be something different on your case
Old Jan 21, 2024
I’ve watched the video he posted. Mine sounds identical. Also happens only when cold, also happens when I put it in drive or reverse. Once the car is warmed up it doesn’t happen…. So I’m positive it’s the same thing, not something else…
I don’t have a hoist to lift it up.
Old Jan 21, 2024
a jack will do... Heat shields are around the exhaust, one or two...
or take it to a place that can do for you, if you don't even have a jack...
Old Jan 21, 2024
Could be a sign of a different problem, particularly in reverse. Check out your passenger side motor mounts, both the "dogbone" and the gel-filled ones. If you started noticing excessive vibration when shifting out of park, I'm willing to bet at least the gel-filled one is worn out.
Old Jan 22, 2024
Colin42's Avatar
Not even a jack?
how are you planning on fixing this?
Old Jan 22, 2024
Originally Posted by Colin42
Not even a jack?
I do have a Jack and I did lift it up and didn’t find anything loose. I am not planning to fix it myself. I’m planning to take it to a shop..
if I know the issue - I can avoid diagnosis fees….
Old Jan 23, 2024
Colin42's Avatar
Your shop must love you...
Just tell them to fix the loose heat shield.
Old Jan 23, 2024
FRSam's Avatar
Click Here
Any shop I’ve ever been to waives diag fees if you get the work done there.
dha12oks
Apr 5, 2022 08:46 AM
20
Jan 21, 2016 02:11 PM
TomD
Feb 4, 2009 11:38 AM
i5r
Sep 29, 2006 06:27 AM
