Oil Leak [solved]
Old Oct 19, 2022
sdx3812's Avatar
sdx3812 is an unknown quantity at this point
Oil Leak [solved]
Any ideas on where this oil leak might be from? I replaced the valve cover gasket and its not that. There is no oil anywhere near the gaskets. I'm not sure what the round black disk on the side of the valve casing is. Could it be that?
This is from an 01 DX.
Oil leak near valve casing
Old Oct 19, 2022
Colin42's Avatar
re: Oil Leak [solved]
Cam plug, definitely a known leak point.
Old Oct 19, 2022
sdx3812's Avatar
Ah thats what its called. Thanks.
Old Oct 20, 2022
redlion4's Avatar
redlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the rough
This. Same issue on our 2005 LX SE. Initially thought it was the rear main seal, after doing major work on the transmission. Oil was pooling on the bottom of the motor and garage floor. Was thrilled to find this plug was leaking and fixed it for < $10!
Old Oct 21, 2022
BrotatoChip's Avatar
Super Moderator
FYI the part number is 12513-P72-003. Yes, around $10 and very easy to replace.
crajnai
Transmission
Sep 18, 2022 08:35 AM
Justmetony
Jun 6, 2022 08:13 PM
redlion4
Dec 13, 2020 12:18 PM
