White smoke after replacing alternator
Old Jul 16, 2022
2004civicgal's Avatar
2004civicgal is an unknown quantity at this point
Unhappy White smoke after replacing alternator
Hi Everyone,
I have a 2004 Civic, I just finished replacing the alternator. I reconnected the battery and started it up to test it and have a small amount of white smoke about 20 second later although it seems to be coming from the exhaust on the left side of the alternator. I do get an odd burning smell but can't identify it. Both of the belts on the right side are turning.
I had all the classic signs of a bad alternator when it went out, flickering headlights, incorrect readings on the voltmeter, failing to charge the battery, etc. I don't believe anything was wrong with any other part of the engine but I suppose it's possible.
It was the original alternator, so I had to use PB penetrating spray on almost every bolt since some had never been removed. I tried to be careful with shop rags but there is no doubt that penetrating spray and WD-40 have sprayed on things it shouldn't have.
As a girl, this was a major feat to replace this alternator, so I am going to go cry for a hour, eat some ice cream and then will be back later to see if you have ideas..
What could I have screwed up? How do I test it and how much do I need to worry about the car starting on fire while I try to diagnose my problem?
Thank you so much for any insights you can offer.
Old Jul 16, 2022
Colin42's Avatar
Re: White smoke after replacing alternator
Probably just overspray from the pb blaster burning off the exhaust
Old Jul 16, 2022
Colin42's Avatar
And triple check all the alternator bolts are tight
Old Jul 16, 2022
Is it better to burn it a few minutes at a time or one longer session? How long would you guess it would take to burn off?
Should I check anything electrical before attempting a burn off session? Will I need a fire extinguisher handy?
And...thank you kind internet stranger for replying.
Old Jul 16, 2022
Make sure you do this. Loose bolts will cause bad ground and fry your ECU
The smoke is likely the PB Blast burning off as mentioned above
Old Jul 16, 2022
Colin42's Avatar
Just let it run in the driveway with the hood up and the car jacked up so you can see everything and keep an eye on it for 10-15 mins. As long as you don't see heavy smoke you're fine
throbscottle
Nov 11, 2011 09:30 AM
gearbox
Jan 31, 2005 02:29 AM
Gecko
Oct 5, 2004 06:32 PM
Gaza
Jul 9, 2004 09:27 PM
chefjnr
Nov 19, 2002 06:20 PM
