Loss of performance + High usage of gas
Old Feb 10, 2022
Ascendingc's Avatar
Ascendingc is an unknown quantity at this point
Hey there! Been browsing around here for a couple weeks now, and since I'm blind on the issue of my car, thought I should give this forum a shot!
2005 Honda civic SI 1.7L standard.
255xx
From the beginning.
I made the stupid mistake of running car with no oil, literally bone dry. I know I know, shame on me.
Car wouldn't turn on what so ever, there was no smoke, or breaking/Knocking noises when I started it. but once I got oil into it, and left it for an hour or so it started up.
Now, when it started up, I noticed an instant decrease in performance And also noticed I was going through a lot of gas after a couple days.
People where telling me my pistons where toast/My engine. but it ain't pushing blue, there's no knocking or disturbing sounds from engine. And I had a mechanic look at it, and he said my engine was not damaged, but he didn't know why I had a decrease in performance etc.
Only issues is using lots of gas, and decreased perform (Acceleration, power, speed kinda thing)
Only code I'm getting is P0172 (System running rich Bank 1)
I checked Fuel injectors, they good.
Did compression test.
Came back as 160 along all four cylinders.
Replaced all 4 spark plugs
Map sensor is good. Cleaned it out.
Replaced the Upstream O2 sensor.
So I'm kinda stumped on what it could be, anybody throw any ideas out there for meplease?
*EDIT forgot to mention my fuel trims seem to be way outta whack.
Old Feb 10, 2022
Re: Loss of performance + High usage of gas
try to reset ECU? compression 160 is not too bad
Are you loosing coolant? is the overflow reservoir full?
Old Feb 10, 2022
Ascendingc's Avatar
Not loosing coolant, overflow reservoir is good. And I've reset ecu.
Old Feb 12, 2022
Colin42's Avatar
What brand did you use for the o2 sensor?
Also check timing
Old Feb 12, 2022
Ascendingc's Avatar
Also check timing
Hey! I used Denso O2 Sensor!
And also, speaking of my timing. My cam shaft timing is actually off a tooth. But my crank timing is dead on the notch. Would the cam shaft timing being off a tooth make a difference? I'm in the middle of putting it to TDC
Old Feb 12, 2022
Colin42's Avatar
It can certainly make a difference.
And Denso is the correct sensor provided it's not counterfeit. Where did you get it from?
Old Feb 12, 2022
Ascendingc's Avatar
I got it from there website.
Is there any chance you think my engine is duped ? Or did I maybe get lucky?
Old Feb 13, 2022
how long did you run the engine without oil?
Did it overheat?
Old Feb 13, 2022
Ascendingc's Avatar
Did it overheat?
I ran engine with out oil for around 30 seconds or so, didn't over heat, no smoking, no loud disturbing noises
dmand
Sep 22, 2021 02:33 PM
theRedhatch
Dec 27, 2019 04:04 PM
qzany89
Feb 10, 2011 10:50 PM
qzany89
Feb 10, 2011 09:45 AM
civicproblems
Engine Swaps
Dec 27, 2007 08:13 AM
