1991 Civic Si b16a Swap fouled plugs poor gas mileage
Old Feb 8, 2011
qzany89's Avatar
qzany89 is an unknown quantity at this point
Have a 91 civic Si with a b16a swap in it. Car was not starting a few days ago, turned out to be fouled spark plugs (all of them). Replaced them and the car fired up and ran great for about 5 days. Now the car will not start again, plugs appear to have already been fouled out. I also am only getting 13-17 mpg. ENGINE IS RUNNING EXTREMELY RICH. Here is my question
I know that this car has a bad o2 sensor (check engine light code points to it). Could a bad o2 sensor really be the cause of this poor gas mileage and how quickly my spark plugs are fouling? The plugs were coated with carbon, not oil. Engine does not leak or burn any at all.
Could a bad fuel regulator be causing this? My fuel regulator also appears to have a adjuster dial connected to it. How do I test the fuel regulator or adjust it?
What else could it be? Dizzy? Dizzy cap? PCV Valve? Fuel injectors? Fuel regulator? Fuel filter? Any help would be great appreciated, I am stumped.
NOTE: Problems appeared to begin happening after I adjusted my FITV and cleaned my IACV. Could this be related at all? Came to this forum as a lot of you out there are much more experienced than me! Please help!
Old Feb 10, 2011
RobTapps's Avatar
RobTapps is an unknown quantity at this point
Re: 1991 Civic Si b16a Swap fouled plugs poor gas mileage
i would check your injectors.. pull them off and get a buddy to turn the key well you check to see if they are firing right, if there fine you might also check your fuel filter and fuel lines. try that and check back
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
Thees1
Apr 14, 2015 08:23 AM
MY01HX
Nov 12, 2001 04:25 PM
