Timing belt noise
Old Oct 6, 2021
Kdubski's Avatar
Kdubski is an unknown quantity at this point
Timing belt noise
Hey you guys, sorry years later but I have a timing belt noise question. I was doing a valve adjustment today and as I crank my engine by hand I can hear creaking like a floorboard or a door. Definitely coming from the cam pulley area. Possibly from the water pump too I can’t tell. This is a new sound as I just did an adjustment last week. I’ve created my own forum as well if you guys would please take a read.
https://www.civicforums.com/forums/3...ease-help.html
I really need the help with my car. I just want it to run good
here’s a video of the creaking sound discovered today, the sound came out well
Old Oct 8, 2021
Wankenstein's Avatar
Re: Timing belt noise
What specs did you tighten the intake and exhaust valves to?
Old Oct 9, 2021
I only hear the wrench clicking and the valve whoosing noise...
on the other hand, thanks for separating your issues by post and adding a link to you other issue - makes the responses better and more organized.
Old Oct 9, 2021
Kdubski's Avatar
.007 exhaust .009 intake for the lash and 14ft lbs torque
Old Oct 9, 2021
Kdubski's Avatar
Ok so that whooshing noise you’re hearing is actually the power steering pulley squeaking which I think is the whistling I hear while driving as well. once you hear the creaking you can’t unhear it lol it’s one of those things but it actually sounds like a creaky floorboard like something is bound up. like I said this sound is new since the last time I was adjusting the valves
Old Oct 9, 2021
Can remove the p/s belt temporarily if it helps isolate the noise.
Use an auto-stethoscope, long screwdriver (24" or more), or a two foot piece of 1/2" PVC pipe to your ear to probe around and amplify noises. Harbor Freight sells an auto-stethoscope and a pair of long screwdrivers (flat and Phillips) for $5 or less.
Old Oct 9, 2021
Kdubski's Avatar
ok will do! Thanks for the input
Philharmonic
Jul 12, 2021 09:43 AM
WaryDriver
Aug 22, 2015 06:50 PM
mistororange
Apr 4, 2014 10:39 PM
jimmyjames1387
Feb 15, 2013 11:57 AM
rileyb22
Mar 25, 2012 07:26 PM
