Timing belt noise
Timing belt noise
Hey you guys, sorry years later but I have a timing belt noise question. I was doing a valve adjustment today and as I crank my engine by hand I can hear creaking like a floorboard or a door. Definitely coming from the cam pulley area. Possibly from the water pump too I can’t tell. This is a new sound as I just did an adjustment last week. I’ve created my own forum as well if you guys would please take a read.
https://www.civicforums.com/forums/3...ease-help.html
I really need the help with my car. I just want it to run good
here’s a video of the creaking sound discovered today, the sound came out well
Re: Timing belt noise
I only hear the wrench clicking and the valve whoosing noise...
on the other hand, thanks for separating your issues by post and adding a link to you other issue - makes the responses better and more organized.
Can remove the p/s belt temporarily if it helps isolate the noise.
Use an auto-stethoscope, long screwdriver (24" or more), or a two foot piece of 1/2" PVC pipe to your ear to probe around and amplify noises. Harbor Freight sells an auto-stethoscope and a pair of long screwdrivers (flat and Phillips) for $5 or less. Last edited by Wankenstein; Oct 9, 2021 at 07:19 PM.
Use an auto-stethoscope, long screwdriver (24" or more), or a two foot piece of 1/2" PVC pipe to your ear to probe around and amplify noises. Harbor Freight sells an auto-stethoscope and a pair of long screwdrivers (flat and Phillips) for $5 or less.Thread
WaryDriver
Aug 22, 2015 06:50 PM
mistororange
Apr 4, 2014 10:39 PM
rileyb22
Mar 25, 2012 07:26 PM
