General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Alternate oil filter for 92-95 Civics?
Old Sep 23, 2021
knuckledragger's Avatar
knuckledragger is an unknown quantity at this point
I have a 95 CX with an 8 valve 1.5 engine and 249xxx miles. I just changed oil (again), and was wondering if anyone has been able to source a double length filter for these cars. I currently have a Wix 21334 filter on it, with M20-1.5 threads and 2.475in dia gasket (standard sizes). On old Chevy trucks there is a spin on filter that holds another quart of oil. I am hoping there is a filter for these cars that is twice as long, since there is plenty of room behind the engine. Filter manufacturers are not much help, no cross reference is available using the thread and gasket size as searchable fields.
I am somewhat new to the Civic world, so apologize if this subject has been flogged to death previously.
Old Sep 24, 2021
Re: Alternate oil filter for 92-95 Civics?
need to ask: Why?
Old Sep 24, 2021
Colin42's Avatar
Originally Posted by sdaidoji
need to ask: Why?
Agreed, why?
Never seen one significantly longer/taller, seen some wider ones. The fram civic filter is much wider than a stock filter, probably only holds an extra 150 mL though
Old Sep 24, 2021
BrotatoChip's Avatar
Super Moderator
Trying to go longer in-between filter changes?
Old Sep 24, 2021
Why? There is no downside to having more oil in the lubrication system. Not trying to go farther between changes. If I can add 1/2 quart by simply using a larger filter, the engine has that much more lubrication capacity.
Old Sep 24, 2021
Colin42's Avatar
Nothing that will add that much. If you're serious about this you could see if anyone makes a larger capacity oil pan for the d series, or weld one up yourself
Old Sep 24, 2021
plenty of things in the internet, but main ones are:
the oil filter drains when engine is stopped. You will need to overfill otherwise your engine will starve while running.
since the filter drains when the car is not running, takes longer to fill the filter when starting the engine
https://www.jeepforum.com/forum/f13/...filter-120150/
https://www.cartalk.com/blogs/tom-ra...ger-oil-filter
https://www.oildepot.ca/use-longer-oil-filter/
https://bobistheoilguy.com/forums/th...2#post-1288440
https://bobistheoilguy.com/forums/th...filter.145363/
and more. I will write this off as internet mith
jbander
Nov 14, 2013 12:34 PM
civic_guy_386
Oct 26, 2012 06:39 PM
03CivicEX4Door
Aug 23, 2005 12:29 AM
chicohonda02
Jul 30, 2005 06:07 PM
Voiceofid
Jun 11, 2003 11:36 AM
