fan not turning on
Old Nov 20, 2020
click4chips's Avatar
click4chips is an unknown quantity at this point
fan not turning on
hey guys...
i have a 2007 civic LX... noticed i had some coolant in my lane way .... on the front drivers side... popped the hood and the overflow was all wet, took it for a drive and when i was driving it was find but whenever i came to a red light or at the drive threw the temp jumped... 3/4 of the way and even a little higher.... cranked the heat and once i started to drive again it dropped, got back home popped the hood and and let it run and i noticed the fans never came on and the temp was getting hot again.... so after talking to some people they said oh it sounds like the coolant temp sensor so i went and picked one up and replaced it ... no luck... as soon as i hit the AC button both fans turn on!, im not a car guy by any means
if anyone had any ideas? maybe a relay switch? i cant seem to find a diagram for 2007
thanks in advance
Old Nov 24, 2020
BrotatoChip's Avatar
Super Moderator
Re: fan not turning on
Check coolant levels. Radiator low? Reservoir high/low? Get both at the correct level then go for a drive. Once you get back let it completely cool and check the levels again, are they the same?
Old Nov 24, 2020
What fault codes does it have?
Nmneas021318
Sep 11, 2020 10:49 PM
jfickel
May 17, 2012 12:35 AM
dan k
Jul 27, 2011 05:08 PM
TRIZ
33
Oct 20, 2009 08:37 AM
dcjose20
20
Sep 11, 2008 10:14 PM
