fan not turning on
fan not turning on
hey guys...
i have a 2007 civic LX... noticed i had some coolant in my lane way .... on the front drivers side... popped the hood and the overflow was all wet, took it for a drive and when i was driving it was find but whenever i came to a red light or at the drive threw the temp jumped... 3/4 of the way and even a little higher.... cranked the heat and once i started to drive again it dropped, got back home popped the hood and and let it run and i noticed the fans never came on and the temp was getting hot again.... so after talking to some people they said oh it sounds like the coolant temp sensor so i went and picked one up and replaced it ... no luck... as soon as i hit the AC button both fans turn on!, im not a car guy by any means
if anyone had any ideas? maybe a relay switch? i cant seem to find a diagram for 2007
thanks in advance
thanks in advance
Re: fan not turning on
Check coolant levels. Radiator low? Reservoir high/low? Get both at the correct level then go for a drive. Once you get back let it completely cool and check the levels again, are they the same?
Nmneas021318
Sep 11, 2020 10:49 PM
jfickel
May 17, 2012 12:35 AM
dan k
Jul 27, 2011 05:08 PM
TRIZ
33
Oct 20, 2009 08:37 AM
dcjose20
20
Sep 11, 2008 10:14 PM
