Question about alignment after lowering
Old May 27, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
noob here, I did a couple searches and didn't get the results I was looking for. I'm purchasing coilovers soon and know I will need a camber kit and alignment not to long after. my question is this: do I need to buy an alignment kit (like eibach), or can I just go to any mechanic and tell them to align me? Also, if you have time to recommend a great camber kit, i'd appreciate it [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Thanks
Old May 27, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
All you should need to buy is the camber kit. Just take it back to your dealer so they can set it to factory specs for both camber and alignment.
As for the camber kit, either Hotchkis or Ingalls make good ones. Check out the Parts section...I believe there are links available there.
Old May 27, 2002
Will1725's Avatar
Will1725 is an unknown quantity at this point
Question does lowering your car void the warranty? I was told if u just did springs no.
But if you put on coilovers yes.Help me out.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 27, 2002
VNlilMAN's Avatar
The Standard One
whether its springs or coilovers it'll probably void your suspension warranty(i've heard some dealers say its ok if they install the springs themselves). any other warranties, no. just remember by law, they have to prove the lowering of your car messed that(whatever the problem your having) up.
Old May 27, 2002
Exactly...my dealer installed the lowering springs and the camber kit. I had a rear damper fail and they actually replaced both under warranty
Old May 27, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
Yeah it is pretty much up to the dealer you go through. You don't need an alignment kit, but it wouldn't hurt if you did get, well, maybe your wallet.
Old May 27, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
but after u lower the car and installed the camber kit, it would be wise to do alignment once to save some treads of the tires
Old May 27, 2002
Mex's Avatar
Mex
but I don't need an alignment kit to get an alignment? What's the point of those exactly?
Old May 27, 2002
VNlilMAN's Avatar
The Standard One
if you get an alignment without an alignment kit, they will probably fix everything but the camber. since your camber is off your alignment is still technically off.
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
aultman1990
Jul 9, 2015 08:27 PM
robbie374
Jul 7, 2015 02:56 AM
