Help on Lowering w/ ground control???
I am in the middle of lowering my 2k2 right now...and went to go put the first ground control coilover on the front.....and it will not fit over stock shock......I have already searched the forums
What do I need to do or did I get the wrong set of coilovers from ground control???????
THANKS
THANKS
The Standard One
maybe this would help ground control install
"The shock cartridge nut is removed so the coil over can be slipped on to the shock body. With the coilover sleeve slipped onto the shock, the four hex bolts that correctly align the spring with the upper perch can be tightened."
you know you got to cut the perch that hold our big a$$ front springs
or you wont be able to adjust the coilovers it says it in honda tuner
and i got ground controls it easy...
Team Turismo
Team Turismo
juror
Suspension DIY
Jul 30, 2019 03:28 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
brainwashedmc
Jul 27, 2015 10:05 PM
