Honda not Starting after seafoam treatment
Old Sep 1, 2018
Bealiebeach's Avatar
Bealiebeach is an unknown quantity at this point
Okay I have a 2004 Civic DX Coupe has 190,000 miles on it.
So I just got this car and was trying to just do some preventive maintenance to make sure everything was operating at the best it could. So I decided to do seafoam. Did the can in the tank, 4 OZ in the oil, then was doing the spray into the intake. When I was about half way done with the bottle it kinda shook and made my hand slip off the throttle and it died. So I went to start it to keep the treatment going and it now will not start.
It turns over but doesn't even try to start. So far I have waited two days to make sure the seafoam had evaporated. I checked the spark plugs today and decided to change them. Still no luck. There is no check engine light that is on. I got some starting fluid and still no start and not even close to starting.
I'm thinking ignition coils but there is no check engine light. I'm planning on checking the cylinder compression as well. Does anyone have any other ideas or has had this happen?
Old Sep 2, 2018
Slumpertcivic's Avatar
Re: Honda not Starting after seafoam treatment
Try removing the top O2 sensor, you might have actually blown the final straw worth of junk to completely seal up the catalytic converter.
Old Sep 2, 2018
Wankenstein's Avatar
Cylinders may be flooded? Try cranking the engine with the gas pedal fully depressed (WOT). This will disable the injectors and allow maximum airflow.
Old Sep 2, 2018
Colin42's Avatar
Pull the spark plugs and crank it, see if anything come comes out, if they reek of seafoam leave the plugs out overnight and try again
Old Sep 2, 2018
Probably flooded it, plugs got wet and now won't fire.
Might also have a pool of liquid down in the bottom of the intake manifold. You might want to extract that out of there before it decides to cause more problems
Old Sep 2, 2018
How would I do that? Just looks down in there?
Old Sep 2, 2018
I'll give this a try as well. I will have the Coils tomorrow and will replace them all really quick.
Old Sep 2, 2018
I tried this sadly it didn't help.
Old Sep 3, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
You should not be buying and changing parts. You will just create more and separate problems. Verify you have fuel pressure and the injectors pulse, verify spark, don't start buying parts.
Old Sep 3, 2018
so I checked for spark did not have spark. All fuses are good and the timing belt. Is not broken.
Old Sep 3, 2018
RobertD's Avatar
I would recommend rechecking with a plug grounded to a good ground that you reeeeally have no spark, and then waiting from some of the smarter minds here why that might be. I can't imagine four coils could possibly fail at the same time, and usually those are not returnable, so I'd hate to see you waste money on something you don't need.
Old Sep 3, 2018
RobertD's Avatar
Read the similar 04 civic no spark thread here for ideas and testing info thread here: https://www.civicforums.com/forums/3...-no-spark.html
Old Sep 3, 2018
I verified there is no spark. I took each plug and put it up against the block in order to ground it and there was no spark. I'll check out that link.
Old Sep 3, 2018
Are you sure the ECU is even on? Hook a code reader up to it? Check engine light starts on, but turns off?
Next I would check all the harness ground connectors on the engine and frame.. by check I mean unbolt, clean, apply dab dielectric grease and rebolt.
Dont ignore fact previous owner might have put some aftermarket thingajob on it thinking no one is gonna steal it now and forgot to tell you about it....
Old Sep 3, 2018
so I checked for spark did not have spark..
4 coils do not go bad at the same time.
Test, don't guess.
Old Sep 3, 2018
Solved it. It was a fuel pump fuse. Does the car not spark if that fuse is blown?
Old Sep 3, 2018
Depends on which fuse it was. Some cover far more than just what is listed on the label. .
Which position number in which fuse box?
WHY did it blow?
Old Sep 3, 2018
WHY did it blow?
Under the dash. Number 13 the fuel pump one
Old Sep 3, 2018
According to the manual i have in front of me:
Fuse 17 is labeled fuel pump.
Provides power to SRS, PCM terminal E9, and main relay #2
Soooo yea if the PCM is missing one of its power sources I can see it not letting anything work including everything for ignition (spark) output.
But what caused the fuse to blow?
Old Sep 4, 2018
I guess the seafoam? Seems weird but that is what seems like what happened .
Old Sep 4, 2018
If you didn’t submerge your car in seafoam I don’t think that would blow a fuse. Possible gunk got loose and stalled fuel pump... not likely but that’s only senario I could imagine.
Old Sep 4, 2018
RobertD's Avatar
i would guess that all the violent shaking and rumbling caused the wiring to bounce around quite a bit, probably an intermittent loss of connection or intermittent short. just a wild guess though
after my last sea foam incident, i kinda outgrew the stuff. this: https://www.civicforums.com/forums/2...ml#post4743074
thank you for coming back and reporting the fix (:
Old Sep 4, 2018
No problem thanks for the help everyone.
Charlesfillier
May 8, 2018 10:32 AM
Michael Corichi
Feb 5, 2017 08:38 PM
I_wantaDOHC
Nov 28, 2014 07:01 PM
Biocide
Dec 9, 2013 06:03 PM
HootieMcMints
Sep 7, 2011 02:16 PM
