10th Generation Civic 2016-2021 Discussion for the 2016 to 2021 Honda Civics.
Chassis codes: FC1, FC2, FC3, FC4, FK4, FK7, FK8
2017 Civic doesn't make sound when remote lock/unlock
Old May 20, 2018
tarapada's Avatar
tarapada is an unknown quantity at this point
Hi folks, hoping you can help - I can't get my 2017 Civic LX Sedan to chirp or honk when locking or unlocking. I have changed the setting in the system menu but it still isn't working. Any suggestions would be really appreciated - thanks!
Old May 20, 2018
Re: 2017 Civic doesn't make sound when remote lock/unlock
LX = horn honk with locking double tap (default setting).
Does the horn still work when you push on the drivers airbag, or did it quit?
Make sure all 4 doors are closed completely
Make sure the hood and trunk are both closed completely
If it's still under warranty and it's broken then take it to the dealership
(hood latch switch may be a suspect)
Old May 21, 2018
tarapada's Avatar
Thanks man - yeah horn was working last time we tried it. Also, if anything is open, the car would indicate this on the info panel right? It always does when trunk, doors, etc. are open while car is started...
Have to find a Honda dealer willing to look at it without charging an arm and a leg!
Cheers
Old May 21, 2018
I don't think it will tell you if it thinks the hood is open. I don't have a similar car in front of me to check though.
Charging you? It's under warranty, yes?
srimad
Mar 22, 2018 12:02 AM
Cody Brace
Nov 13, 2016 09:46 PM
Moparboi
Jul 9, 2013 05:55 PM
Jenni
18
Apr 9, 2008 11:14 AM
chokingvictimva
Jul 23, 2006 07:28 PM
