2003 Honda Civic LX rear passenger window not working
Old May 9, 2018
DrGottagupta's Avatar
DrGottagupta is an unknown quantity at this point
Hey everyone,
I recently picked up an '03 Civic LX, wonderful car. I've been wanting to get the windows tinted but the rear passenger window does not go down at all. All other windows work fine.
Here's what I've done so far:
Replaced Master Switch
Replaced Passenger Door Switch
Replacing the switches has not resolved the problem. You can hear a click when you press the drivers switch and passenger switch. Any tips will be greatly appreciated.
**UPDATE**
Thanks for the suggestions everyone, turned out to be the window motor that was bad.
Old May 9, 2018
Re: 2003 Honda Civic LX rear passenger window not working
Wire harness is probably broken in the rear door jamb area where it flexes every time the door is opened and closed.
I'd replace the door harness if it actually broke any of the wires. It's cheap enough that I won't bother patching them anymore at work.
Old May 10, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Also check the driver's door jam harness as well for a broken wire. This repair fixed my rear passenger window not going back up.
Old May 14, 2018
Notagain Honda's Avatar
Notagain Honda is an unknown quantity at this point
I had that problem and replaced my window motor and it worked fine
Bryan Tomesch
Sep 18, 2016 11:21 PM
8Radiant
Jan 30, 2014 07:17 AM
canadian_l3acon
Jan 17, 2014 06:38 PM
clueo8
Aug 22, 2005 06:13 PM
mr_fobster
Apr 20, 2005 08:44 AM
