Passenger Power Window Not Working
Old Aug 19, 2005
clueo8's Avatar
clueo8 is an unknown quantity at this point
I have a 2002 Civic EX Coupe.
I've been having this problem with the passenger power window. I checked both the fuse box under the steering wheel and under the hood... No blown fuses... This happend to me once before and I checked the fuses, and I must of bumped something, cause it started to work for awhile... Now I can't get it to work... What could I have bumped, or what could be the problem?
Old Aug 19, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
does it do anything? No sounds? nothing? Do you hear the motor kicking in?
Old Aug 19, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
I know this might sound stupid, but did you check the lockout switch on the drivers door? That got me when i was checking a car out after doing an install the other day. I started taking the door panel off to check the connections when another installer walked over and pressed the button and the window worked. I must have hit the swtich when I was putting the drivers side door panel back on.
Old Aug 19, 2005
clueo8's Avatar
No, no sounds at all... its not jammed or anything like that... Originally when I bought the car a year ago... I noticed that window didnt work... I had them fix it before I bought it... it might be the same thing... I want to call the place I got it from, but they probably forgot what they did.
Old Aug 19, 2005
clueo8's Avatar
No, I did check the lockout switch... I called the place I bought the car from, and they said they replaced the whole window regulator assembly. I don't really know what that is or if its an easy thing to replace. I think its wierd I got it working again when I went to check the fuses the first time I noticed it went out...
Old Aug 22, 2005
clueo8's Avatar
I took the side panel off the door yesterday... I was moving some wires around and discovered that the first small 2 wire harness after the window control button wasn't touching as well as it should be... I bent a few ***** on the male side and also on the female connector and it seemed to have done the trick! Thanks to everyone for your help!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
got2kids
May 9, 2015 06:45 PM
ORskier
May 3, 2015 12:54 PM
