ball joint change
Old Sep 9, 2016
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
ball joint change
i unscrewed everything and now im left with this tied.
how can i get this off, i already took the bolt off. and whats this.
Old Sep 9, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Re: ball joint change
that is the abs sensor pull it off slowly.
good luck.
Old Sep 9, 2016
thanks, its really stuck in the rust. can i spray it with something or just try to pull it out one shot?
Old Sep 9, 2016
mikey1's Avatar
your pic is bart simpson, so just do what you think he would do, either that or call flanders to help
Old Sep 9, 2016
so since i cannot get the abs sensor off without probably breaking it, i should unplug it from where its connected and just get the whole piece with the cable. is that possible?
and when getting a ball joint off, should i press it out from where its a flat surface of from where the screw is?
Old Sep 9, 2016
You probably can't get the sensor out without destroying it. Follow the wires and unplug it.
I have to do this all the time when replacing wheel bearings.
SightScout
Sep 7, 2016 04:41 PM
dnmacdon
Sep 6, 2016 01:01 PM
BootyDo
Aug 21, 2016 09:25 AM
novice121
Aug 18, 2016 09:03 PM
chi_tea
Aug 17, 2016 01:52 PM
