How I solved my dash rattling..
Old Aug 14, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Well solved most of it anyway. My dash rattle was really getting out of control. I also was experiencing some clunks on bumps and when brakes were applied mostly from the front of the car. These have gotten gradually more noticeable over the last 3 months. I replaced the stock front lower control arms, stock front end links, and stock ball joints. (Also put new rotors on the front). This was my first attempt at control arms ball joints etc. It was fairly easy once I got the right ball joint press. Some stores carry a press whose metal sleeves are just a millimeter too wide to allow for the receiving sleeve to fit over the ball joint and not push against the knuckle. All that said the car drives really good now, no clunks and.... the dash rattle is virtually non-existent.
Old Aug 15, 2016
GolNat's Avatar
Prelude Owner
Re: How I solved my dash rattling..
glad you figured it out. That can get annoying.
I think the last time I rented the ball joint tool I had to get a special "Honda" kit to go with it.
Old Aug 15, 2016
Dooner's Avatar
GOT SAND?
Dooner is an unknown quantity at this point
I just did both lower control arms, stabilizer end links, ball joints, and inner/outer tie rod ends. Didn't have the dash rattle though. Car does ride better, and the steering is a bit tighter then before for sure. There is a special ball joint tool for Hondas, and for what it's worth, there's a Honda inner tie rod tool as well. Found that out the hard way. For the life of me, I can't figure out why Honda designed the lower control arms the way they did. They should pivot in an up & down motion like most A-arms do.
Old Aug 15, 2016
thanks for the heads up on the tie rod tool. mine are the original ones and I'm sure they are worn as well after 225K miles. They will need changing when i can get to them.
E Sully
Jun 2, 2016 09:00 PM
ishmot
Jan 2, 2016 09:53 AM
h4ldol
Dec 24, 2015 02:35 PM
Tack
Suspension
Dec 16, 2015 12:29 AM
steve6
Nov 22, 2015 08:18 PM
