Should I replace the head-cover gasket whenever I you remove the cylinder head?
Old Aug 12, 2016
manfredww1's Avatar
manfredww1 is an unknown quantity at this point
I am taking the headcover off to replace my TDC sensor in my 2002 Civic ex. Should I replace the rubber gasket when I open the cylinder head?
Edit:
I should ask, do I have to ? I am trying to avoid replacing the gasket because I do not have the part on hand and i need to do the TDC sensor tomorrow morning.
Last edited by manfredww1; Aug 12, 2016 at 05:04 PM. Reason: Added additional material
Old Aug 12, 2016
mikey1's Avatar
Re: Should I replace the head-cover gasket whenever I you remove the cylinder head?
it is so cheap i would replace it,
if not (depending on how old it is) you could rub a very light coating of high temp silicone on it using your finger....you are supposed to use silicone at the corners anyway
Old Aug 12, 2016
you can get it in the parts store nearby anytime... check their websites to see where they have it...
Old Aug 12, 2016
IF the gasket is still soft and pliable, you can probably reuse it. If it's baked and hardened, it may end up leaking.
Dab a little RTV in the sharp corners like the original had.
Try it out. If it leaks later on, it's pretty easy to replace.
alex_nyc
27
Jun 16, 2019 08:27 PM
kingrat
Nov 11, 2015 01:37 PM
GoBruin02
Jan 4, 2002 12:54 PM
JoeNC
Dec 22, 2001 03:18 PM
Sledge
Dec 7, 2001 12:09 PM
