Neons inside the middle air vent
Old May 16, 2002
Sosojef's Avatar
Sosojef is an unknown quantity at this point
Does anyone have a DIY on how to get behind the middle air vent and insert some neons lights?
and also if I can hook up wires from the neonlight withouth the use of the cigarrette lighter adapter. thanks in advanced.
Old May 16, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
to get behind vents...u can look at the DIY for painting trim , this will show you how to remove the center console/vents.
Old May 16, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
it's also the DIY headunit install. not very hard and it'll probably look better if you wire it from behind without the plug =O)
Old May 16, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
I want/plan on "blue"ing my entire dash (very similar to Drew), so if anyone can lemme know on what products they bought (like neon lights, LEDs) and wiring schemes, I would greatly appreciate it. I guess basically I'm looking for a DIY. The one's posted for redo-ing the dash dont work.
Old May 17, 2002
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i put neon blue strobes in my driver and passenger a/c vents
Old May 17, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
you could hard wire them to prevent tapping into cig lighter. you'd just have to buy a switch of some kind to prevent killing you battery after you turn the car off. if you bought the street glow brand, there are instructions on how to do that on the back of the package. you cut off the cig lighter plug, and wire to switch and then run the wire to your battery, and a ground. that's a simplified version.
Old May 19, 2002
Voiceofid's Avatar
End Bringer
i didn't use neons, instead, i brought some led washer nozzles and took the led off and stick them into the vent
Old May 19, 2002
RegulatorRacing's Avatar
RegulatorRacing is an unknown quantity at this point
woah those neons would look tight..
blazebrown
18
Jun 2, 2019 12:31 PM
steelfan95
Jun 19, 2015 07:15 PM
crowtoo
May 11, 2015 06:50 PM
Ronin
Apr 18, 2002 10:14 PM
OPGForce
Feb 7, 2002 09:43 AM
