Civic stalls and smells like gas
Hey everyone. I've got a 2001 Honda Civic. For the past month, the car has gradually taken longer to start. On a cold start, probably a solid 6-7 seconds. When I get in the car in the morning (even before starting) it has a strong gasoline odor. Just drove it 2,000 miles last week. When hitting the steep mountains west of Denver, CO it began to loose power and finally stalled going up the mountain (7-8K ft elevation). Got it towed back down to Denver (~5,000 ft elevation), and it started right back up. Anyways, now it will drive for several hours okay....then it will eventually stall out. If I turn it off for a little bit, I can start it up and drive a couple more hours.
My gut says it is a fuel problem. Maybe a fuel pump?
EDIT: I'm not really sure how to hook up a fuel pressure test gauge to this vehicle, don't see a service/access port.
Re: Civic stalls and smells like gas
Use your nose to figure out which end of the car the smell comes from?
Engine compartment, or rear by the fuel tank
Then look and feel the fuel lines and injectors and rail to see if there is liquid seepage or leakage
Got any fault codes? EVAP system leak codes?
Gas mileage figures down? (if you calculate at every fill up)
To better access and monitor the fuel rail, is it okay to temporarily run the car without the air filter/resonator?
That bad? If it stinks that bad you should be able to find the leak pretty easy IMO
Got puddles on the ground or wet streaks on the outside of the gas tank? Pull the back seat and inspection cover and look at the top of the tank/pump? (cracked pump cover?)
Well, jacked the car up and saw a sizable leak coming from the gas tank. Not sure where the leak originates from. Maybe I could drop the tank a little bit to get a better view.
I've attached a picture. What would be a probable leak point towards the top edge of the tank?
I'll add the possibility of rodent damage, they seem to like some of the plastic fuel lines over here for some reason.
Didn't remove the access plate though.
Don't drop the tank without a damn good reason.
Dry it all off then cycle the key and see if gas is coming up through the cracks in the flat yellow area.
That housing is the fuel filter, it can be purchased through aftermarket sources without the fuel pump but some people have issues getting it assembled correctly.
Honda only sells it with the pump assembly.
https://www.youtube.com/watch?v=6mvg...ature=youtu.be
Ayup, it's junk.
This can be fixed without removing the fuel tank, which would have been a whole lot of unnecessary work. That entire unit will come up through the access hole.
You just need the right tools to get the threaded ring unscrewed....then reinstalled after repair.
Quit running/driving it. You're a fire hazard.
Thanks ezone for your help. I've replaced the fuel pump assembly and no more leaking. However, I noticed when I got in the car yesterday, it still had a smell of fuel. Putting my nose to the fuel pump assembly (access plate removed), I smell fuel. Is this normal? If so, does the access plate and seat act as a buffer to the fumes normally?
The cover needs to be in place. Yes it helps seal out air/mice/smells.
There may be a lot of spilled fuel that has to evaporate before the smell goes away.
Make sure there aren't still leaks of any sort though, or it won't quit stinking.
If everything is properly assembled, there shouldn't be any (new) gas smell.
do you have any gas soaked gunk still on the underside of the car from when it was leaking? make sure you get rid of all the old gas residue.
Well, still a slight hint of gas in the car. I took the seat and plate back off. It's dry as a bone. Took the car up in the mountains around here and after going up from 2,000 to 4,000 ft the car began to stall out again. Pulled over and put it in neutral, car struggled to rev. Shut the car off for about 10 minutes. Started back up and drove just fine going back down where I parked it at home. The area that was leaking before is still dry after the pump assembly was replaced, but it is possible there is some air that is able to get in the tank, as it seems some fumes are escaping around the gasket and locking ring causing the cabin to have a slight gas smell.
Got any ideas?
Got any ideas?
Got an OBD2 reader that can check the onboard emission test monitor status? See if the EVAP monitor (test) has run and passed.
I'm not familiar with altitude change strategy programming in those. I live in flatlands, never dealt with mountains.
Also, I don't have an OBD2 reader yet, so don't think I can run t hat test unless it is something the local auto parts guys can do with their scanner.
I know when I was in Colorado (also when going up a mountain) a couple weeks ago, I tried turning it off for a minute and starting again, it ran okay for a couple minutes, then went back to stalling performance. Only after letting it sit for a good bit (30+ minutes) was it good to go for the rest of the day (back on relatively flat terrain)
I think I'd want to be able to view live operating data (datalist) on a good scanner while it acts up.
They try to pick out any sensor data that doesn't look as expected, if that's even present and possible. Assuming this is an electrical/electronic failure, not mechanical.
https://www.youtube.com/watch?v=ZVh1...ature=youtu.be
Engine temps began the rise at one point (about 3/4 up the gauge). When I finally got it home, popped the hood and the engine was steaming slightly. Had auto parts guys run a code scan (since the CEL is on). Registered the following codes:
* P0740: Torque Converter Clutch Solenoid Circuit / Open
* P1361: Top Dead Center Sensor Noise
* P0700: Transmission Control System
Before the most recent 2,000 mile trip, the car was shifting and running great, so not sure if it is a sensor, torque converter, or what.
P1361: Top Dead Center Sensor NoiseP0740: Torque Converter Clutch Solenoid Circuit / Open
I'd probably just replace the sensor first (Honda part, not a cheapo), since it seems to be heat related and intermittent. Replace and see if the same code returns on the next trip.
P0740 code.....Unplugged TCC solenoid? Broken? Bad solenoid?
Has the CEL been on this whole time, before you started the thread???? Always check fault codes out first and foremost.
Chase this P1361 code first. Is the sensor bad? Did the code set during the poor running event? Does the cam have excessive end play?
P0740 has been on almost since I bought the car May of 2015. Besides the code, never had any symptoms of anything wrong with the transmission, shifts like a dream. That was the only code on, until today or recently. I've had it checked about every other month while at the auto parts store to make sure there weren't any new codes.
I guess the fuel pump assembly leak had me going down a fuel direction for a diagnosis. No doubt it needed to be replaced, but obviously didn't solve the problem.
I'll chase the P1361 code now.
I should probably also mention, that about 3 weeks ago, when the vehicle stalled going up the mountain in Colorado, I took a video of the engine after starting it up again.
https://www.youtube.com/watch?v=tYlf...ature=youtu.be
It was moving/vibrating more than usual.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
steve6
Nov 22, 2015 08:18 PM
Nalmonte
Nov 17, 2015 12:55 PM
Bartkat
20
Feb 19, 2002 01:29 PM
