Stuck in the middle with you
Hi Civic peeps,
With ezones help I got power to my starter and alternator. The starter turned the engine slowly and no spark (not turning fast enough?). Had starter checked, NG, new battery putting out 640 cvs, 12.65 volts. I pulled all four plugs and turned the engine with a socket on the crank. How easily should I be able to turn it? I want to make sure it is not seized due to daughter running hot with blown head gasket. Thanks!
Robin ; )
Robin ; )
Re: Stuck in the middle with you
should spin pretty easily, i remember turning a 6th engine that still had the plugs in it with a breaker bar and not much eeffort
Won't turn at all? ****, well that might do it, might want to try 2 days.... Might have to start looking for a replacement engine. Hopefully you can get it freed up.
If the spark plugs are installed, you would be trying to work against compression as you turn the crank.
Then do a compression test
t.ralsty
Jul 2, 2016 10:24 PM
damahark
Oct 28, 2015 08:11 AM
