Stuck in the middle with you
Old Jun 26, 2016
Tz779's Avatar
Tz779 is an unknown quantity at this point
Hi Civic peeps,
With ezones help I got power to my starter and alternator. The starter turned the engine slowly and no spark (not turning fast enough?). Had starter checked, NG, new battery putting out 640 cvs, 12.65 volts. I pulled all four plugs and turned the engine with a socket on the crank. How easily should I be able to turn it? I want to make sure it is not seized due to daughter running hot with blown head gasket. Thanks!
Robin ; )
Old Jun 26, 2016
Colin42's Avatar
Re: Stuck in the middle with you
should spin pretty easily, i remember turning a 6th engine that still had the plugs in it with a breaker bar and not much eeffort
Old Jun 26, 2016
Tz779's Avatar
Hmmm, ok I'll try 1/4 cup of Mystery oil in each cylinder?
Then return in the morning and try again? Thanks for the help!
Old Jun 26, 2016
Colin42's Avatar
Won't turn at all? ****, well that might do it, might want to try 2 days.... Might have to start looking for a replacement engine. Hopefully you can get it freed up.
Old Jun 26, 2016
So it's not locked up.
Socket and extension and ratchet, without any spark plugs in it it should easily turn two complete revolutions by hand counterclockwise with little resistance once it's moving. It will have a bit of resistance from a standstill.
If the spark plugs are installed, you would be trying to work against compression as you turn the crank.
Hasn't the starter been replaced yet? Replace it!
Fix starter first.
Then do a compression test
t.ralsty
Jul 2, 2016 10:24 PM
damahark
Oct 28, 2015 08:11 AM
pnamajck
Oct 27, 2015 07:09 AM
AZ2K1Civic
Jan 5, 2002 08:38 PM
LexBoy
Jan 2, 2002 07:59 AM
