best manual for timing belt, water pump repl. 01 Civic
Old Apr 10, 2016
mscir's Avatar
mscir is an unknown quantity at this point
I have a 2001 Civic Ex with 110k mi. I want to replace the timing belt, tensioner, water pump, and transmission oil. I've done head gaskets, break jobs, clutch replacements, and tuneups on older vehicles, so I'm confident that I can do this job if I have a good manual and buy any tools I need, e.g. a torque wrench. What manual is recommended, I would like exact instructions for my year and engine, pictures are helpful, and torque spec's.
Also, there are a lot of timing belt kits on ebay, are any of them worth buying? Or does anyone have a source they recommend?
Thanks,
Mike
Old Apr 10, 2016
mikey1's Avatar
Re: best manual for timing belt, water pump repl. 01 Civic
timing belt "kits" will cost you more money in the long run after they fail and you bend valves, buy honda OEM parts,
there is a good guide here on this site if you search
Old Apr 10, 2016
Do you care about your engine not bending valves?
Old Apr 10, 2016
Casey Shovey's Avatar
Casey Shovey is an unknown quantity at this point
I dont think you necessarily have to get oem theres decent kits online i just got one its aisin water pump and mituboshi belt with seals but im gonna get a better tensioner probably oem
Old Apr 10, 2016
mscir's Avatar
I found this on the autohausaz site, I'm not familiar with Aisin, does "Aisin OEM" mean these are OEM parts?
TKH003 - Aisin OEM - Timing Belt Kit with Water Pump
http://www.autohausaz.com/pn/TKH003
Any comment on a good manual for this job?
Also how do people lock the harmonic balancer in place while they remove the nut holding it to the crank?
Old Apr 10, 2016
I used the factory manual combined with the diy here for things the manual does not cover
Aisin is one of OEM suppliers
Old Apr 11, 2016
mscir's Avatar
I'll look for a factory manual then.
Great, there are some good prices on the web sites this group collected.
Thanks!
Mike
I can't reply to mikey1's post because the yotube video expands and covers the reply textarea. Any chance you can remove the video? I've seen that one.
What do you think of using the starter to loosen the bolt? The starter applies torque to the ring gear which spins the flywheel, which spins the crankshaft. So as long as the car doesn't fire the journals should get damaged. What do you think?
Last edited by mscir; Apr 11, 2016 at 02:08 PM. Reason: can't type in textarea obscured by youtube video in next msg.
Old Apr 11, 2016
mikey1's Avatar
Aisin are decent parts, they make parts for toyota i believe, but i would go factory OEM on the tensioner,
there is a special tool you need to buy to hold the crank while you loosen the bolt, that bolt can be a pain, i use an 18 inch breaker bar with a 6 foot steel pipe over it......
Honda Crank Bolt & Harmonic Balancer Removal DIY - YouTube
ht....tps://www.youtube.com/watch?v=icj0j3LH9L4
Old Apr 12, 2016
Sea Bass's Avatar
Sea Bass is an unknown quantity at this point
I recently did a timing belt change on my car. The DIY found on this site was basically all I needed. I printed it out (all 30-something pages or whatever it was) and kept it handy during the whole process. As a back-up I kept my Chilton's manual nearby but I didn't need it much.
One tool I would buy that isn't explicitly mentioned in the DIY is an appropriate-sized cheater bar for the crank pulley bolt. I spent about $13 at Lowe's and got a 12 foot galvanized pipe to slide over my breaker bar. I got the crank bolt in one try. ONE.
Old Apr 12, 2016
mscir's Avatar
Thanks Sea Bass, I'll search for the procedure on this site and print it out exactly as you say.
What do you think of the procedure some guys use - mount a socket and breaker bar on the crank pulley bolt and then just touch the starter a few times to break it loose?
Old Apr 12, 2016
You cannot do that on this engine. Engine spins the wrong direction.
Old Apr 12, 2016
mscir's Avatar
Thanks again!
Old Apr 13, 2016
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Thanks again!
I bought a craftsman 1/2 19v impact. Removed crank bolt right away. Was a great excuse to add it to my tool collection
Old Apr 14, 2016
mscir's Avatar
That's a great idea. Thanks.
Old Apr 15, 2016
Check if youtube link is no longer embedded in that post for you now
Old Apr 15, 2016
mscir's Avatar
You nailed it, I can see the page again! Thanks!
Old Apr 15, 2016
bsmiley's Avatar
This one includes wiring diagrams.
2001 Honda Civic Repair CIVIC SEDAN:
https://drive.google.com/file/d/0BzK...ew?usp=sharing
The battery impact I bought:
Old Apr 15, 2016
mscir's Avatar
Nice! Sears is selling them for $90! Did you use this to retorque the bolt, and if so, how did you avoid overtorquing it?
The link to the manual may be old, "Sorry, the file you have requested does not exist."
Old Apr 15, 2016
bsmiley's Avatar
https://drive.google.com/open?id=0Bz...WxhNkV6aWxTeFU
Old Jun 11, 2016
mscir's Avatar
Very thorough manual with great illustrated step by step instructions, thank you!
Old Jul 13, 2016
S14's Avatar
S14
S14 is an unknown quantity at this point
This is the tool I used on my 240 to hold my harmonic balancer. Also worked well with my wife's 2001 civic.
Not sure if you can get it anywhere but the snap on truck but it's the best tool I have ever had.
And this.
Old Jul 13, 2016
cheesy's Avatar
cheesy is an unknown quantity at this point
I did my timing belt a year ago with nothing more than an iPad and YouTube. Went very smooth.
Did the head gasket disassembly the same way, but bought a Haynes manual to reassemble fur quick reference to various specs. It is lacking for sure, but does point out some things I would have missed.
Old Jul 14, 2016
mscir's Avatar
Thanks very much for posting that, it looks perfect for the job. Great photos too!
Old Jul 14, 2016
S14's Avatar
S14
I like to help others find better ways to work on their toys.
My civic was puking coolant out every couple of days. So I just started to attempt to fix it before the wife says get rid of it. Never really got this deep into Honda's it's always been Toyota and Nissan but in the end it's all nuts and bolts. Oh yeah I just fixed my water pump,replaced the belt and tensioner,and unfortunately had to ditch my timing belt lower and upper covers due to the last guy the owned it.
Old Jul 15, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
in my opinion you can't go wrong with piercedasian and ratchets and wrenches 7th gen civic timing belt vids on you tube. Both those guys are very thorough.
the oem kit on amazon is what I got 109$ worth every penny. here it is.
dont forget to get the valve cover gasket as well.
good luck.
Old Jul 15, 2016
mscir's Avatar
Thanks!
Old Jul 30, 2016
S14's Avatar
S14
It was the one of the easiest timing belts I have ever done aside from a Toyota Tercel lol!
Also i was having an issue with overheating again after the time belt water pump replacement and pulled the temp sensor connector and tested the wire jump bypass and found out the sensor was bad and caused overheating. If that might help someone down the road your welcome.
Old Jul 31, 2016
mikey1's Avatar
uuummmm.....those parts are not OEM....not even close
Honda doesn't make a "kit", you need to buy all the parts seperately
Old Aug 30, 2016
mscir's Avatar
Thanks to everybody who commented, got my car back together today, my first timing belt, it's running great. Really great forum, thanks!
