A/C Issue
Old Feb 19, 2016
jlalbers's Avatar
jlalbers is an unknown quantity at this point
A/C Issue
The A/C in my car is not working. When I press the A/C button, it does not light up. I think it is a fuse, but I want to see if anyone else has experienced this issue and what the solution was.
Old Feb 25, 2016
Wankenstein's Avatar
Re: A/C Issue
Could be a fuse or bulb or fault (break) in wiring. Is the A/C working properly otherwise?
Old Feb 25, 2016
jlalbers's Avatar
Re: A/C Issue
Negative. The A/C does not work at all.
Old Feb 25, 2016
Re: A/C Issue
So, are you asking us to help you figure out what's wrong with the a/c system or just the switch not lighting up?
Is the blower motor working on all speeds?
Did you check related fuses and relays yet?
Is the compressor engaging?
Read some of these: https://www.google.com/?gws_rd=ssl#q...ac+not+working
Youngrob650
Nov 12, 2015 11:01 PM
MauricioParilli
Oct 15, 2015 09:43 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
Hwoody77
Dec 29, 2001 10:04 AM
NukeSilo
Nov 4, 2001 09:37 PM
