A/C Issue
A/C Issue
The A/C in my car is not working. When I press the A/C button, it does not light up. I think it is a fuse, but I want to see if anyone else has experienced this issue and what the solution was.
Re: A/C Issue
Could be a fuse or bulb or fault (break) in wiring. Is the A/C working properly otherwise?
Re: A/C Issue
So, are you asking us to help you figure out what's wrong with the a/c system or just the switch not lighting up?
Is the blower motor working on all speeds?
Did you check related fuses and relays yet?
Is the compressor engaging?
Read some of these: https://www.google.com/?gws_rd=ssl#q...ac+not+working
Youngrob650
Nov 12, 2015 11:01 PM
