Fast response needed: Drilled accidental hole in trunk
Old Feb 16, 2016
shaejb15's Avatar
shaejb15 is an unknown quantity at this point
LOL. Just by reading the title you can tell i'm a DUMBASS.
Installing the OEM spoiler on a 02 civic coupe and with my template foamy things I drill the hole for the harness. Well my dumbass forgets when the spoiler goes on the template is actually the other way. Ugh. So now I have this 10mm hole in my trunk that shows and doesnt work and need it patched up. See the pictures. What do I buy and how do I do it? Ik i wont get it perfect but I can live with it.
Thanks
Old Feb 16, 2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Fast response needed: Drilled accidental hole in trunk
Get U a bullet hole decal or use a bandaid
Old Feb 16, 2016
Wankenstein's Avatar
I don't know **** about body work other than what I read on-line but here's my guess. Cheapest and probably easiest way might be to pull the trunk lid off the same year (or 7th generation), model and color from a junkyard.
Other option: You could either tack weld or possibly JB Weld a silver dollar-sized piece of sheet metal (Home Depot) from underneath the hole if it's not a braced area, then use Bondo on top, smooth and touch up paint. Even with touch up paint it will be most likely noticable but, much cheaper than remvong the lid and spraying it properly with base and clear coat.
Old Feb 16, 2016
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I would probably go this route. If you keep the repair as small as possible it should be mostly hidden by the spoiler.
Old Feb 17, 2016
mikey1's Avatar
trunks can get stuffy, its good to have extra ventilation
Bikergofast
Mar 9, 2016 07:08 PM
Supramk3
Oct 6, 2015 12:52 AM
ken4444
Oct 4, 2015 10:50 AM
General DIY
Sep 25, 2015 08:02 PM
LilCivicKidd
Nov 9, 2001 05:22 PM
