cold air from heater
Old Jan 18, 2016
Mv7fd's Avatar
Mv7fd is an unknown quantity at this point
so when I'm driving the heat will burn your hand when your driving but when you come to a stop it's cold like i have the air condition on. i've been having problems with loosing antifreeze but i figured out thats it's coming out from the overflow bottle underneath the cap. so what causes this to happen.
Old Jan 18, 2016
tkcne's Avatar
tkcne is an unknown quantity at this point
Re: cold air from heater
Probably a head gasket.
Old Jan 19, 2016
mikey1's Avatar
a blown head gasket
Old Jan 19, 2016
CraigW's Avatar
Never a good sign.
Old Jan 19, 2016
Wankenstein's Avatar
1) Replace radiator cap with OEM if, not working properly.
2) Check coolant overflow hose and reservoir for blockage: probably not issue since it overflowing but never hurts to check.
3) Pressure test coolant system.. maybe clogged radiator
4) Pray 1, 2 or 3 is the issue otherwise most likely HG as others said.
Want HG breach confirmation do a Block Test and/or Leakdown Test.
cscounts
16
Jan 17, 2016 01:35 PM
bratzcpa
Jan 1, 2016 11:40 PM
ej8_Sosa
Dec 23, 2015 04:03 PM
Vapy
Dec 22, 2015 09:23 PM
