Both windows stopped rolling down, and power locks wont work.
Old Dec 25, 2015
vdubbin95's Avatar
vdubbin95 is an unknown quantity at this point
Okay I have searched it and have come to the conclusion it may be the wiring. My friend owns a 2001 civic dx and all of a sudden both his windows stopped working. I checked the fuses and they are all good. I put my working switches on his doors and still doesnt work. The chances of both his motors going bad at the same time are not possible. What should i be looking for since neither door switch works for rolling down the window, the fuses are all good and my working switches from my civic dont work in his car....
NEXT. My car. Both my windows work but my power locks wont work. I can manually lock them (passenger lock goes about half way down but still engages). When i press the button I hear clicks on both doors. Nothing happens though. i took apart the door cards and could not find any broken/ corroded wires and all vacuum lines are fine, and the fuses are all fine also. Any ideas?
If these issues have been posted 1000x im sorry for the repeat.
Old Dec 25, 2015
Re: Both windows stopped rolling down, and power locks wont work.
DX doesn't have power windows. Problem solved!
Ok, you may want a wiring diagram and volt/ohm meter.
I'll SWAG it's broken wire(s) in the drivers door jamb.
Turn the key on, hold the window switch up (or down) and s-l-o-w-l-y open and close the door, see if the window moves at all.
If so it's broken a wire.
Hopefully a broken wire will still be close enough to make contact as the door moves and the harness flexes.
If so, my opinion is that buying a door harness is cheap compared to wasting a ton of time to hack in a patch that may not last very long.
DX has manual locks. Problem solved!
No?
If you can see the motors attempt to pull on the lock ****, the motor is usually assumed to be weak.
Weak/bad lock motors are common. Replace.
If no action is seen/heard, use a voltmeter or test light to verify the system is supplying power and ground to run both (or all 4) actuators, just to make sure it is not a wiring or control unit problem.
There are zero vacuum lines in the doors. WTF are you checking?
Old Dec 29, 2015
vdubbin95's Avatar
Ill give it a shot. Ill pull the harness apart today. And i am trying to sell my civic so i want everything working instead of saying oh well the door locks dont work and the SRS light is on and bla bla bla
Old Dec 29, 2015
vdubbin95's Avatar
as for the vacuum lines... i had a 95 GTI that had vacuum lines for the door/ trunk locks.
Old Dec 29, 2015
You checked the wrong car! Problem solved!
Gotta love those wacky German cars and their ideas of central locking. Not.
Old Dec 29, 2015
vdubbin95's Avatar
haha yeah! Minor details!
Old Dec 31, 2015
vdubbin95's Avatar
okay so the power lock on my civic... when i press the button i hear the clicking on both doors... i check the harness leading under the dash and there arnt any broken wires. What else could be wrong?
Old Dec 31, 2015
WIring diagram and volt-ohm meter. GO!
Old Jan 1, 2016
vdubbin95's Avatar
i dont wannnaaaaa lol
Old Jan 1, 2016
Put your big girl panties on and suck it up soldier!
Old Jan 2, 2016
vdubbin95's Avatar
Okay so this is what i have so far. I bypassed the switch. I set up a jumper from my cig lighter to the power lock wire and all it did was make the same clicking noise in both doors. I put the jumper from my battery to the power lock wire and the same thing happened. So its not a break in my wires or the jumper would have activated this. could it be the actuators? but the chances of them both going bad at the same time is impossible...
Old Jan 2, 2016
Locks? Oh damn I thought you were still on the windows. I can't read.
You could stick a test light (or #194 bulb) in the power lock connector to see that it lights up when the button is pushed, verifying power and ground. That would indicate the lock actuator is bad.
Noise with partial or no movement should be bad actuator.
Old Jan 8, 2016
vdubbin95's Avatar
ill give it a shot!
fvckbg
Oct 20, 2016 07:37 PM
wingsfan19
Oct 1, 2015 03:45 AM
mhsmom
Aug 31, 2015 10:45 PM
cecisd15
Aug 11, 2015 02:53 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
