Is there any way to lubricate door lock actuators without replacing?
Old Nov 19, 2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
We have a 2000 and 2002 Civic and the actuators work, sorta, they're just sludged up and need lubricating. ( WD40? )
Is this feasible?
Old Nov 19, 2015
Wankenstein's Avatar
Re: Is there any way to lubricate door lock actuators without replacing?
Is this feasible?
Did you remove the door panel and shine a light on the actuator?
Just a plastic arm that moves. You could try a spray bottle with 90/10 mix of water/dawn dish liquid to clean it. After that use silicone spray lubricant.
More than likely the actuator is on it's way out and will need replacing soon.
Old Nov 19, 2015
No, I haven't done that yet, but actuators are only about $18, so if I'm going to do all that, I may as well replace them.
Are they hard to get to?
Old Nov 19, 2015
Depends on coupe or sedan, back or front doors; Youtube
Just a warning for aftermarket replacements.. Dorman brand parts usually suck and that's why they're inexpensive. Up to you though.. I pulled one from a local junkyard for $7 (OE) for my '97 (6th gen) EX coupe.
The 7th gen actuators are easier to replace.
Old Nov 20, 2015
Thanks. Shoulda mentioned that I have a 2002 Civic Ex with Vtec engine, 4 doors. Unusual but I have one. Had to look for a long time but actually found one that way.
And the 2000 is a plain old LX but with a VERY awesome engine that actually has more pep and perk than the Vtec in the other car. Don't know how to describe it, but it does.
Old Nov 20, 2015
CraigW's Avatar
On 01-05s I think the little DC motor gets weak.
They use a plastic grease to lube the gears, and case surrounding is pretty much sealed.
Other Honda units likely similar. (01-05 seems to be worst)
Old Nov 20, 2015
What was that about 7th generation being easy to change?
I also need to change at least one in the 2000 Civic, though.
Old Nov 20, 2015
CraigW's Avatar
The fronts are mounted to the latch assembly at the back edge of the doors. The latch comes loose with 3 screws, and there is linkage to release (plastic swivel clips) and remove linkages from latch.
File Type: pdf
Old Nov 20, 2015
Argghhh. I'm having a problem with the rear drivers side one on the 2002.
From that link, it looks like these are expensive too.
What about the 2000 Civics ( 4-door LX )? Anyone know how difficult they are?
Because these don't seem like things that the average mechanic does, and if they do, it aint cheap?
Old Nov 20, 2015
CraigW's Avatar
You want to make sure it is getting voltage before replacing (broken wire in door harness) Listen closely & watch lock **** while locking/unlocking to determine if voltage is reaching actuator.
This shows the location for rear actuator.
File Type: pdf
Old Nov 20, 2015
Argghhh. I'm having a problem with the rear drivers side one on the 2002. From that link, it looks like these are expensive too. What about the 2000 Civics ( 4-door LX )? Anyone know how difficult they are? Because these don't seem like things that the average mechanic does, and if they do, it aint cheap?
If you want parts cheap go to U-pull junk yards. Another benefit of U-pull is that you get to practice on parts instead of the one's on your car.
Watch Youtubes on parts replacement.. it will take out some of the guess-work for you.
Old Nov 20, 2015
I'd do them all day long if anyone were willing to pay for the service.
02, rear, maybe 45 minutes?
00, rear, maybe an hour?
Old Nov 20, 2015
Mechanics around here get about $85 an hour. I don't know what the units cost though.
Now it looks like we need 2 replaced in the back doors of the 2002 and one replaced on the front passenger side of the 2000.
EliseKStewart
Jul 15, 2015 11:11 AM
Kyles24
Jul 12, 2015 09:15 PM
mapdog
30
Jun 24, 2015 02:46 PM
Khmi
Jun 23, 2015 11:03 PM
Sledge
Dec 7, 2001 12:09 PM
