2003 Civic EX Auto, oil burning problems.
Old Aug 28, 2015
totravska's Avatar
totravska is an unknown quantity at this point
My 03 EX has just shy of 150k miles on it, and it has been burning oil for as long as I've had it. It's not leaking anywhere, I've inspected it as well as multiple other mechanics. When I first got the car it had a blown head gasket which I had fixed, as well as the timing belt, tensioner, and water pump I believe.
Some other minor repairs as well.
My car just won't stop burning oil, however. Could it possibly be the piston rings? What are some ways to check that?
I use high-mileage oil by the way. I used to use 5w20 but have been using 5w30 for some time now.
Thanks, I appreciate any help
Old Aug 28, 2015
Re: 2003 Civic EX Auto, oil burning problems.
Yep.
If it's not leaking, then it's got stuck oil rings. Stuck with carbon buildup is the usual cause.
Did switching to 5w30 improve the consumption?
Try switching to 0w20 instead.
Old Aug 29, 2015
emich's Avatar
emich is an unknown quantity at this point
Originally Posted by ezone
Yep.
ezone is there a way to clean this carbon buildup?
Old Aug 29, 2015
The quickest, surest way is to pull the pistons and rering it.
You can try soaking cylinders, you can try seafoam and snake oils, you can try whatever you want...no promises.
(When I did my Fit engine rering a couple weeks ago, I pulled out the pistons and soaked them in Mopar Combustion Chamber Cleaner which is some of the best carbon cutting stuff available IMO (it's hazardous to people in California LOL)....soaked for a couple days. While it did get the rings to loosen in their grooves, there was still a whole bunch of carbon that had to be cleaned out manually.)
You could switch to oil with different specs and hope it can clean from the inside (crankcase)...Search the forum for ILSAC and ACEA and read my comments.
You can search for "Saturn" and find descriptions of what I've been doing to my GFs car over the last several years. It's been sloooow process but it's definitely been an improvement.
And lastly, the old school thinking of switching to 'heavier' oil to slow down oil consumption does not always work as expected in modern engines. Switching to 'thinner' oil may. 0w20 anyone?
Old Aug 29, 2015
emich's Avatar
I'll swich to 0w20 is synthetic better?
I change already head gasket, t. Belt etc. I am reluctant to take out the pistons unless I get something like your Fit. It's not so bad 1 qt. for 6000 mi.
Old Aug 30, 2015
0w oils are already considered synthetic in the US.
I think it's easier to get the head off a belt drive engine.
Stripping the nose of an engine to get to the timing chain can be a PITA.
That's not bad at all IMO.
I don't think I'd take it apart if that's how fast it uses oil.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
