MICU replacement question
Old Aug 19, 2015
ErosRamazzoti's Avatar
ErosRamazzoti is an unknown quantity at this point
Hello Guys
There was a multi problem on my 2001 Civic
I changed MICU for another one.
All previous problems disappeared BUT
Now I have PARKING blocked.
There is no signal to solenoid to unlock when I press break pedal
So
How to re-programm new MICU? Or something wrong with him?
Thanx in advance
Old Aug 19, 2015
Re: MICU replacement question
Post/thread moved.
MICU is plug and play as far as your problem is concerned.
I suggest you double check you got all the connectors fully seated, and check all the fuses are in the correct holes
and you got all of the relays swapped into the new fusebox.
Was your new unit actually brand new?
Was it a used part?
If it was used, was it correct for your car? There may be dozens of different versions of the fusebox/MICU.
Old Aug 23, 2015
Thanx Guys
I have got it.
It was 01 pack for manual (standard) transmission. It does not have shift lock/unlock.
I change it for 02 pack for automatic and now its ok.
Thanx
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
thesushiboy
Apr 12, 2015 02:54 AM
viper775
Dec 9, 2001 10:52 PM
