8th Gen 2006 - 2011.
Vsa
Old Aug 4, 2015
Siguy1's Avatar
Siguy1 is an unknown quantity at this point
Vsa
Hello I'm a new member I ha e 2007 civic si the vsa light stays on the whole time and no codes come on the reader can somebody help? I would really appreciate it thanks
Old Aug 4, 2015
Re: Vsa
I suppose you are trying to use a generic OBD2 reader? That won't work for ABS/TCS/VSA.
Gonna have to see what code(s) are stored first.
A trip to the dealer may be in your future.....or a well equipped Honda specialty shop that can scan it.
One other question: Do you have HID headlights?
Old Aug 4, 2015
Siguy1's Avatar
Re: Vsa
At first it would come on and off now it's been a month and stays on all the time.
Yes I do have a hid lights
Old Aug 4, 2015
Re: Vsa
Many people strap their HID ballast to the ABS unit and it causes problems with the ABS computer through HF interference. (ABS/TCS/VSA are all controlled within in the same unit)
Mount your ballast as far away from the ABS unit as possible and keep the HV wires routed as far away as possible.
If there are codes stored you aren't supposed to be able to clear them by disconnecting the battery..... Needs a correct scanner to read and clear memory.
If there are codes stored it really needs checked out properly first. Figure out if it is a real problem and all that.
Old Aug 4, 2015
Siguy1's Avatar
Re: Vsa
Thanks I'll make sure they are as far but I know it's not on the actual unit but thanks I guess I'll have to go to the dealer
rogerpop
Sep 29, 2019 10:33 AM
nijac
Apr 16, 2012 10:58 AM
nijac
Apr 3, 2012 10:41 AM
2009EXL
Sep 22, 2009 08:47 AM
