Sway Bar end links - time to change?
Old Jun 5, 2015
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Everytime I take an exit (I meant a steep right turn), the car kinda feels like running on a series of speed brakers on the passenger side.
Even the smallest of potholes, sounds cruel!
Noise is really stupid, feels as if there ain't any shocks at all on the car.
Took it to a mechanic (pepboys) to get it checked, was told the sway bar end links needs to be replaced.
Is that so???? Appreciate your input. Thanks.
Old Jun 5, 2015
Re: Sway Bar end links - time to change?
Your mechanic should be able to demonstrate why the links need replaced.
Struts can also get noisy, but links are cheap and (somewhat) easy so if they are bad then do them first and see what happens.
Browse this thread?? Check the pictures of the broken swaybar link
https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/362829-parts-replacement-alignment.html
Old Jun 6, 2015
GolNat's Avatar
Prelude Owner
I would unhook the links from the LCA and see if the noise goes away if you did it yourself. Pepboys will charge you for that at which point you should replace them since they are cheap and easy to get too.
I would check struts and mounts as well.
Old Jun 6, 2015
mrohitredd's Avatar
Lower ctrl arms, struts, tie rod ends are about an year old...
I can probably ignore them all...
Will check the links in couple days...
Old Jun 9, 2015
mrohitredd's Avatar
indeed they are !
Replaced the links last night & the car now drives much better.
For those replacing links for the first time - Mine are 165k miles old & its obvious the nuts are gonna be really tough. I couldnt get them out straight, so I broke the old links down to the metal (ball), held one end with a pipe wrench & twisted the nut. Propane Gas, Saw cut, Nut Splitter - None worked (not enough room to work there). To figure this way, i spent nearly 3 hours on the first & second was under 30 mins. Hopefully this will help someone who ran into the same issue... Cheers !
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
jessepimpride
Nov 13, 2001 05:59 PM
