LED tail/brake lights knocked out my cruise control.
Old May 25, 2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
We have two 1998 Civics.
This is odd. Over the weekend, I replaced all the red tail and brake lights on both cars, and the center high mount brake light, with super bright LED's. ( one Cree LED at the end of each, and arrays around the body of each ).
So today, I find out that my cruise control no longer works when the lights are on, only if I turn the light off. What the....?
Old May 25, 2015
Re: LED tail/brake lights knocked out my cruise control.
I actually found the answer at
http://www.8thcivic.com/forums/mecha...e-control.html
I'm a former electronics technician and diodes are sure better than putting loads on the circuits. But does anyone know if you need a diode on each lamp that has been replaced by LED's?
Old May 26, 2015
CraigW's Avatar
Not a fan of led but, I would try loading the brake circuit with resistors. Possibly both sides.
You can slice the insulation, and tap in without cutting wires.
Old May 26, 2015
Why would I want to add wasted load to the power, when they say that series diodes will work?
Old May 26, 2015
CraigW's Avatar
Do what ever works, you have an 6th gen and the diode mod was used on an 8th.
Better keep a close eye on them, as the track record for reliability is not that great.
Old May 26, 2015
They sure are brighter, something like 2-1/2 times as bright.
Is there something in the circuitry that's THAT different with our generation, where the diodes may not work?
What's the maximum resistance that I could put across the LED's to make it work right again? I'm seeing pretty low resistance and high power being used, or some people just hanging a bulb across them, which sort of defeats the power savings.
Old May 27, 2015
CraigW's Avatar
Really no harm in trying diodes.
You could experiment with load resistors like 15 Ohms and test, you may need to go as low as 6 Ohms
Old May 27, 2015
That's a lot of heat, and may as well hang a bulb on it, if it needs all that.
Old May 27, 2015
CraigW's Avatar
Yes, it is.
The bigger load resistors come with heat sink, and mounting holes.
I have always said.... it defeats the purpose.
KronikScott
Jun 9, 2015 08:00 PM
eorlando1
May 17, 2015 11:16 AM
cukaracha
May 16, 2015 02:11 PM
Supramk3
May 11, 2015 07:55 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
