high irratic idle
Old Apr 21, 2015
vtechcivic's Avatar
vtechcivic is an unknown quantity at this point
high irratic idle
I've recently had another motor installed in my '01 civic lx. Motor is in, everything is buckled up and it will run. Problem is, it seems to have a high irratic idle. I read that it cud possibly be whats called a fitv or fast idle thermo valve bbut also ready tht '96 or newer civics don't have em. any ideas or any suggestions??
Old Apr 21, 2015
mikey1's Avatar
Re: high irratic idle
what is your definition of the word "irratic"
could be a loose or disconnected vaccuum/intake line/hose
Old Apr 21, 2015
vtechcivic's Avatar
Mechanic that did my motor swap said that it would idle from about 2k rpm to 3k rpms. Not fast enough like if one was patting the gas pedal, just idle up for a few seconds then back down...sorry I misspelled irratic. I meant erratic...
Old Apr 21, 2015
Good enough to swap the engine, but not good enough to figure out what is wrong with it?
That says a lot right there.
Huge vacuum leak(s)?
Broke the plastic intake manifold open?
IAC stuck wide open?
Got codes?
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
cgavin1
Jul 7, 2015 07:10 AM
671civicLX
Jul 4, 2015 04:02 PM
1stcivic
Nov 18, 2001 09:17 PM
