Car buck around 40mph and throw P0300 P0302 P0303pd
Old Apr 20, 2015
Blaster30's Avatar
Blaster30 is an unknown quantity at this point
Exclamation Car buck around 40mph and throw P0300 P0302 P0303pd
I have read a lot of the posts about random misfires, but none seem like my issue.
I have a 2003 EX MT
Symptoms: When I drive as I approach 40 mph the car starts to buck or lose power. High RMP or not, like if I get to 40 in any gear. If I stay in the gas, that is when the code is fired. If it bucks and I push in the clutch I am able to rev it up, but as soon as I let the clutch out, it bucks.
Recent work:
Replaced coil pack on cyl: 1 and 2
Timing belt
Crank Shaft Position Sensor
Valve cover
Spark plugs
Radiator cap
Engine Coolant Temp sensor
Rear cam seal plug
EGR gasket (I did not clean the EGR when I had it off)
A couple of weeks ago, I had a cel for O2 sensor, I cleared it and it has not been back.
Where do I go next?
Thanks for the help.
Old Apr 20, 2015
Re: Car buck around 40mph and throw P0300 P0302 P0303pd
Disconnect the wiring plug from the EGR valve.
Drive it, see if the problem is still present or if it is gone.
Report back with your findings.
How many miles are on the car/engine?
Old Apr 20, 2015
GolNat's Avatar
Prelude Owner
What plugs did you use?
Old Apr 21, 2015
Blaster30's Avatar
Unpluged the egr, same result. I have 114000 miles. I replaced the plugs with ngk double platinum, but when the mechanic did the timing belt he replaced them with something else. I will pull and report back.
Old Apr 21, 2015
Blaster30's Avatar
The plugs are Denso PK J20CR - L11
Also, I noticed if I take off fast and push 1st and 2nd gear past 5K rpm it is much better. There is a slight bump as it passes 40mph.
When it is acting up, it almost feels like a dirt bike with bad power reeds. Like it wants to get into the power band, but can't. Does that make since? Is there something like that on the civic? What does the vtec solenoid do?
Old Apr 21, 2015
Recent work:
Did the current complaint start immediately following any of this recent work?
My catalog gives DENSO PKJ20CR-M11 as a correct plug, but I can't tell how close your plug number is to that. Probably close enough to not cause issues..
Old Apr 21, 2015
Blaster30's Avatar
No, i had a couple of weeks without issue. The last thing I did was the engine coolant temp sensor. I think I am going to look at the MAF now.
Old Apr 21, 2015
It does not have a MAF sensor. It does use a MAP sensor.
Old Apr 22, 2015
Blaster30's Avatar
So yesterday, I found that if I pushed it hard in first and second, the problem got better. Today, no issue. Ran smooth as ever.
usajags84
15
Aug 19, 2015 03:12 AM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
toastyghosty
32
Dec 26, 2001 02:03 AM
2001LX
Nov 8, 2001 05:13 PM
