1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Turn key to on, fuel pump primes for 4 seconds then turns off.
Old Apr 16, 2015
McD's Avatar
McD
McD is an unknown quantity at this point
just replaced my ICM in my dizzy, drove it around to find it was in limp mode so took it home and reset the ecu. now the fuel pump turns off after 4 seconds regardless if I try to start the car or not. I've checked all my fuses and I think I've checked all my grounding points. I also have been having the issue with the car stalling at stoplights when I'm under 7/8th's tank. my ECU blinks once then nothing. I replaced my ECU about a month and a half ago when I was having an issue with the automatic one giving my engine issues and swapped it out to the manual one it's supposed to have.
Old Apr 16, 2015
GolNat's Avatar
Prelude Owner
Re: Turn key to on, fuel pump primes for 4 seconds then turns off.
The pump should be audible for about 4 seconds whe it's priming and then stop.
Does the car start?
Clogged fuel filter. Sediment in the bottom of the tank. ECU blinks? CEL?
Old Apr 22, 2015
McD's Avatar
McD
Issue Resolved. The pin for the wire going to the TDC sensor went bad. Re-pin, solder new wire, starts right up.
Old Apr 22, 2015
GolNat's Avatar
Prelude Owner
Good deal. Thanks for updating.
CarStuff
Dec 6, 2020 12:52 PM
jetcare101
May 8, 2015 01:33 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
