reccomended power steering pump 2001 ex
Old Apr 15, 2015
moorebl's Avatar
moorebl is an unknown quantity at this point
just hit 200k and my power steering pump is starting to whine. any recommended units I should buy. ebays, rockauto. links would be helpful
Old Apr 15, 2015
GolNat's Avatar
Prelude Owner
Re: reccomended power steering pump 2001 ex
I would go here:
https://www.hondaautomotiveparts.com...artsSearch.jsp
I think you can rebuild them. Get a used one from a junk yard.
Remove it completely, it's not needed.
Old Apr 15, 2015
I'd first look see if the fluid is low.
Then see if the fluid is aerating, getting foamy in the reservoir. Maybe even belching out the top.
If it is, then the inlet tube in the pump needs the O ring replaced.
Never use ATF in these. Use only Hondas power steering fluid.
Old Aug 29, 2015
emich's Avatar
emich is an unknown quantity at this point
get a rebuild kit and remember turn the shaft nut clockwise to unscrew it. Autozone part # 8950 $28
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
vvr210
May 31, 2015 08:02 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
