1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 civic code reading help needed!
Old Apr 8, 2015
kracker's Avatar
kracker is an unknown quantity at this point
I DONT KNOW IF ITS OBD 1 OR 2, i looked down at the passenger kick panel aand found a loose brown and also black wire and jumped them, check engine light doesnt flash? is this the right wires?
Old Apr 8, 2015
Re: 1995 civic code reading help needed!
CLICKY LINK
Old Apr 8, 2015
Also, this
Old Apr 8, 2015
kracker's Avatar
i jumped those, ign in on position, check eng light doesnt flash its just solid?
Old Apr 8, 2015
Did you get a bunch of other lights flashing while it was jumped?
Old Apr 8, 2015
kracker's Avatar
nope
Old Apr 8, 2015
kracker's Avatar
ok so what is now flashing is my SAS light, gave me a #92. is that supposed to flash?
Old Apr 8, 2015
Key off
Insert jumper wire to blue two pin SCS connector
Turn key to ON (II) (do not start engine)
SRS ABS and ECM should output codes using flash mode
So if your SRS light is flashing when you do this then it's working (the SCS circuit is working and its ground is working)
Could mean there are no codes.
Try creating a code to see if the computer can detect it, like unplug the IAT sensor...then go read codes again, see if it now flashes the correct code for that part.
Old Apr 8, 2015
as info for others reading here, 95 were the last OBDI. 96 and newer are the OBDII
I know because i own a 95 miata...
Old Apr 8, 2015
kracker's Avatar
is this proper?
Old Apr 8, 2015
is this proper?
That code is stored in the SRS control unit memory, so yes.
Had your SRS warning light been staying on?
Old Apr 8, 2015
kracker's Avatar
yes but the check engine light just came on. the code however isnt related to SRS, its a 92, evap cannister
Old Apr 8, 2015
SRS code 9-2 is a power supply system failure.
I see nothing like 92 under engine controls at all. For a 1995 car the ECM stops at code 48 according to my info.
Old Apr 9, 2015
kracker's Avatar
came on after we took the whole dash apart to install bulbs in the heater controls. but we didnt leave anything disconnected...
Old Apr 9, 2015
kracker's Avatar
so why am i not getting a code for the check engine light?
Old Apr 9, 2015
If you dinked with the dash and lights, maybe you caused the light to stay on?
Maybe you should determine if the ECM is keeping the CEL on, or if something else is keeping it on.
Old Apr 9, 2015
kracker's Avatar
we took everything apart and checked nothing is disconnected
Old Apr 9, 2015
I already read that.
Old Apr 9, 2015
If you check a wire diagram, how many different control units can turn on the check engine light?
If you disconnect each of those control units, then turn the key on, now does the check engine light still stay on?
Old Apr 9, 2015
kracker's Avatar
the CEL has gone off but the SAS is still on. we have tore the whole dash apart and checked all connections today. all good.
--still have the SAS light on and code 9-2 and speedo not working
ideas?
Old Apr 9, 2015
There's a whole troubleshooting section in the service manual for the SRS fault code.
I'd probably start by manually erasing the SRS codes and then see if it returns. If it returns then troubleshoot why.
When is the last time your speedo did work?
Got cruise control and does it work?
Got ABS and does it work?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Myredjonda
Apr 14, 2015 07:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
