Sloppy Shifting + Rough Idle + Oil Burning
Old Mar 28, 2015
pinkpony's Avatar
pinkpony is an unknown quantity at this point
01 Civic EX Coupe 165k Miles
Plan of attack:
Sloppy Shifting
  • Aluminum Shifter Base Bushings + Aluminum Cable Shifter Bushings
  • MTF Flush + AutoRX (Should I use Redline, Amoil, or Honda Stuff?)
Rough Idle
Might wait to tackle this after the other 2 are taken care of, maybe it will fix itself
Oil Burning
  • Change PCV Valve
  • 5W20 High Mileage Oil Change + Mobile 1 Extended Filter
  • (Should I put some AutoRX in here as well?)
I live in New England so keep that in mind. It gets cold, and I don't want to keep changing different types of fluids.
Old Mar 28, 2015
Re: Sloppy Shifting + Rough Idle + Oil Burning
Plan of attack:
Sloppy Shifting
Get in there, take it apart if necessary, see what's really wrong first. Then decide what really needs fixed.
I'd drain and fill with Genuine Honda MTF. It's only about 2 quarts.
Rough Idle
K.
Oil Burning
  • Change PCV Valve
With that mileage, I'd expect stuck oil rings.
Got blue smoke?
Do the plugs show oil or white caked buildup?
I'd run 0W20 oil and hope it can clean out the stuck rings before the car wears out.
Burnout
Jul 15, 2022 10:24 PM
RIPSAW
Nov 6, 2015 04:36 AM
The Big Dutch
Jun 9, 2015 07:49 PM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
