Heater does not work on idle!
Old Feb 24, 2015
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
All of a sudden, the heater stopped working. It works "OK" while running but when stopped it blows cold air...
Read few other posts which say it could be a blown head gasket... Is there a way I can check that ?
Not sure if it's related, but my CEL blinks for couple seconds even after I start the engine... Didn't happen before... Got the codes checked at Advance Auto Parts and the guy said it's normal & even the reader found nothing.
Old Feb 24, 2015
Re: Heater does not work on idle!
Air is trapped in the heater core, water pump can't easily push past the air bubble at low RPM.
Why? Low coolant in the radiator. Burp and fill.
Where did the coolant go? Leaked out... or blown head gasket.
Is the check engine light actually connected to the engine computer? LOL
It should not blink while running unless there is a misfire present.
Set a real code (like unplug the IAT sensor) and see if their code reader can detect it.
Old Feb 24, 2015
mrohitredd's Avatar
The coolant flush was done less than 2-3 months ago...
Can i just refill the coolant & check ?
Or is there a better way to check this ?
Old Feb 24, 2015
Is the radiator low?
Is the overflow bottle waaay overfull?
The radiator is supposed to be completely full at all times under all conditions. If it is low, that's a problem.
Old Feb 25, 2015
mrohitredd's Avatar
No coolant at all!
I open the cap to only find it empty. How can I check where the leak is ?
Old Feb 25, 2015
Originally Posted by mrohitredd
No coolant at all!
I open the cap to only find it empty.?
Fill it up.
I'd start with using my eyeballs after filling it up.
Is it running out, leaving a puddle on the ground?
Old Feb 27, 2015
mrohitredd's Avatar
1. stupidity to the peaks !!!
it wasnt actually the CEL that blinked but was the Maint Required... i forgot to reset it after the recent oil change...
2. got the coolants and everything checked... they said, the pressure is fine. the problem is kinda strange... when i put the fan speed low.. it pushed slight heat... when the fan speed is high, it blows cold air... these are all on idle...
i havent changed the Timeing belt & Water Pump... wanted to do that this summer... is this the reason ?
Old Feb 27, 2015
I guess I didn't think of that because you said it only blinked for a couple seconds. I'm used to those blinking for about 10 seconds. At least that was easy!
No coolant at all!
This series of events tells a story......
1) Where did the coolant go? (HINT: It did not grow legs and walk away!)
2) Did the cooling system get refilled?
3) Did the cooling system get 'burped' properly?
4) Did anyone perform my head gasket inspection procedure?
You would have heat again (at least temporarily) if #2 and 3 were done.
You would have an answer as to why, if #4 was done.
I don't know what that means. Not a big deal though.
Not strange at all for these cars, if one has experience with this problem.
i havent changed the Timeing belt & Water Pump...... is this the reason ?
Nope, but the time to do these is while the head gasket is getting replaced.
Old Mar 3, 2015
mrohitredd's Avatar
When i got the car checked at "Monro Garage", they did a pressure test & everything is fine... everything means the liquid too... they topped off the liquid & suggested me to replace the cap. Which i just did #CAP
It was.. as of what the Monro guy said...
i guess so... i just post a 50/50 & planning to do tonight...
I got the car checked at Pepboys & they suggested me to replace the thermostat (only to check if that makes us ignore the head gasket fault). Am curious what do i have to do to check if the thermostat is good or bad (& needs a replacement) ?
I just bought a thermostat, gasket for the same...planning to replace & check, if that helps...
I just drove the car for about 30 mins & its still the same... No change after the coolant refill...
How tough is replacing a HEAD GASKET job ? I got a quote of close to $1000 Cant afford that now !
Old Mar 3, 2015
mikey1's Avatar
depends on where you take it, $1000 is not astronomical for a HG replacement
the cheapest price is never the best job, who do you trust with your car?
you dont want somebody botching a HG job, or your going to be right back in the same mess your in now,
Old Mar 3, 2015
mrohitredd's Avatar
I understand... I usually do some basic work like brakes, suspensions, etc...
Can i do this ?
Any DYI link ???
been searching for one...
Old Mar 3, 2015
mikey1's Avatar
Can i do this ?
Any DYI link ???
i can not access your personal capabilities,
but if you do attempt the job,
it is probably worth the money to buy yourself a repair manual (honda, hayes, chilton), you will need it for the torque specs alone,
Old Mar 4, 2015
mrohitredd's Avatar
SOLUTION (FOR MY SITUATION) - Changing the thermostat & refilling the coolant have helped. I did it last night & just drove the car to work in the morning. I usually heat the car before a drive for about 10-15 mins in winters especially... The heater did what it is suppose to !!!
Thanks all for your time & input.
Old Mar 4, 2015
mikey1's Avatar
give it a week or two....you will likely have the same issue
Old Mar 4, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
You can view/download the pdf repair manual here:
https://www.civicforums.com/forums/1...e-updated.html
R3KogHyZe
21
Feb 3, 2016 09:23 PM
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
1stcivic
Nov 18, 2001 09:17 PM
