Heater does not work on idle!
All of a sudden, the heater stopped working. It works "OK" while running but when stopped it blows cold air...
Read few other posts which say it could be a blown head gasket... Is there a way I can check that ?
Not sure if it's related, but my CEL blinks for couple seconds even after I start the engine... Didn't happen before... Got the codes checked at Advance Auto Parts and the guy said it's normal & even the reader found nothing.
Re: Heater does not work on idle!
Air is trapped in the heater core, water pump can't easily push past the air bubble at low RPM.
Why? Low coolant in the radiator. Burp and fill.
Where did the coolant go? Leaked out... or blown head gasket.
Is the check engine light actually connected to the engine computer? LOL
It should not blink while running unless there is a misfire present.
Set a real code (like unplug the IAT sensor) and see if their code reader can detect it.
Is the radiator low?
Is the overflow bottle waaay overfull?
The radiator is supposed to be completely full at all times under all conditions. If it is low, that's a problem.
1. stupidity to the peaks !!!
it wasnt actually the CEL that blinked but was the Maint Required... i forgot to reset it after the recent oil change...
2. got the coolants and everything checked... they said, the pressure is fine. the problem is kinda strange... when i put the fan speed low.. it pushed slight heat... when the fan speed is high, it blows cold air... these are all on idle...
i havent changed the Timeing belt & Water Pump... wanted to do that this summer... is this the reason ?
The coolant flush was done less than 2-3 months ago...
No coolant at all!
I open the cap to only find it empty.
No coolant at all!
1) Where did the coolant go? (HINT: It did not grow legs and walk away!)
2) Did the cooling system get refilled?
3) Did the cooling system get 'burped' properly?
4) Did anyone perform my head gasket inspection procedure?
You would have heat again (at least temporarily) if #2 and 3 were done.
You would have an answer as to why, if #4 was done.
i havent changed the Timeing belt & Water Pump...... is this the reason ?
I just bought a thermostat, gasket for the same...planning to replace & check, if that helps...
Nope, but the time to do these is while the head gasket is getting replaced.
Cant afford that now ! Last edited by mrohitredd; Mar 3, 2015 at 03:22 PM.
depends on where you take it, $1000 is not astronomical for a HG replacement
the cheapest price is never the best job, who do you trust with your car?
you dont want somebody botching a HG job, or your going to be right back in the same mess your in now,
Can i do this ?
Any DYI link ???
been searching for one...
but if you do attempt the job,
it is probably worth the money to buy yourself a repair manual (honda, hayes, chilton), you will need it for the torque specs alone,
SOLUTION (FOR MY SITUATION) - Changing the thermostat & refilling the coolant have helped. I did it last night & just drove the car to work in the morning. I usually heat the car before a drive for about 10-15 mins in winters especially... The heater did what it is suppose to !!!
Thanks all for your time & input.
You can view/download the pdf repair manual here:
https://www.civicforums.com/forums/1...e-updated.html
R3KogHyZe
21
Feb 3, 2016 09:23 PM
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
