CEL, is it the o2/ air fuel sensor? 2005 civic Ex
I have a 2005 civic EX coupe. I got the codes below from auto zone, Im assuming it's the 02 sensor bank 1 sensor 2, where is the sensor located? the exhaust manifold is not the one with the built in cat. Is the sensor in the code the upstream or downstream sensor?
P1457
P0139
P0420
P1457
P0139
P0420
Re: CEL, is it the o2/ air fuel sensor? 2005 civic Ex
P1457
P0139
Pull yours out and see who made it. It will be NTK or DENSO. Use the original brand sensor. Go to that manufacturers website and look up the correct part number for that sensor for your car.
Don't let the Zoo sell you Bosch.
P0420
okay so start with the sensor? also with the p1457 code, they were saying it needed smoke tested? Should I have it smoke tested?
Attached a pictures of the codes and definitions http://s292.photobucket.com/user/Tyl...?sort=3&page=1
First I use my scanner to activate each solenoid and listen for the CLICK.
The typical failure I commonly see is the CVS valve bad or leaking, but there are other possible causes. Chasing EVAP codes can be a hair pulling experience.
Here's a pic of something that is becoming more common as the cars rust to death: CVS valve rusting apart and leaking externally:
These were taken after the canister was removed from the car and pressurized with about 1 PSI, and I sprayed soapy water on the whole thing so the leak would bubble.
You can see how rusty it is, there's almost nothing left of the screws that hold it to the canister. If the screws can't break loose, the canister will need to be replaced too.
If you still get the P0139 after changing your O2 sensor, you may want to consider taking it Honda to perform an upgrade on the computer. I had the same problem with my 05; was getting a P0139 even AFTER changing the sensor. There is a Honda Technical Service Bulliten on the topic:
www.civicforums.com/forums/attachment.php?attachmentid=77239&d=1252107997
I have replaced my downstream o2 sensor with the OEM NTK sensor $60. I drove my car for 120 miles since the replacement of the sensor, at about 40 miles the CEL light came back on. I had the code run after 120 miles, it was the p1457 code. Hopefully the other two codes wont come back now that the o2 sensors fixed. I guess I should start with the CVS vavle.
I took the evap canister off today and when I went to unscrew the screws that hold on the canister shut valve, the thread inserts came out with the screws, looks like I should jb weld them in place Once I get the new valve?
After getting the canister shut valve off of the canister I pressurized it and it was leaking out the side, I ordered a new one it will be here tomorow. hope it was the only thing leaking.
the thread inserts came out with the screws, looks like I should jb weld them in place the thread inserts came out with the screws, looks like I should jb weld them in place
This is the point where I estimate a new canister along with the CVS valve.
You can try epoxy if you wish, will save a few $$ if it works.
May want to apply antiseize to the threads of the screws as you assemble it too.
Figured I would give an update on the cause of the problem. I fixed the evap leak, it ended up being the Canister shut valve. Since the thread inserts pulled out of my canister I just re-tapped them to 5/16-18, then drilled out the holes for the new canister shut valve. Between that and the new o2 sensor, my CEL light has be off for 150 miles and I passed my echeck. Thanks for every ones help, it saved me a lot of money!!!!!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
dooner24
Apr 14, 2015 07:51 PM
